LS90 Tweaks and upgrades
  • wallstreet
    wallstreet Posts: 1,405
    edited January 2013
    The interesting part here is how are we going to do the A/B testing when you're done? :)
  • Bigerik
    Bigerik Posts: 149
    edited January 2013
    Nice to see the LS-90's getting some love.
  • thsmith
    thsmith Posts: 6,082
    edited January 2013
    wallstreet wrote: »
    They already sounded great but I will know how I like the differences.
    Spikes will tighten up bass.
    New caps and resistors should sweeten the entire spectrum.
    Dynamat will probably not make that much difference since there is not a lot of ringing in the baskets as it is, but its piece of mind and may aid in bass response.
  • stubby
    stubby Posts: 723
    edited January 2013
    wallstreet wrote: »
    I can haul my oak non-modded 90's up for comparison. :cheesygrin:
    SRS 3.1TL
    Harman Kardon Citation 5.1
    Anthem AVM2
  • ken brydson
    ken brydson Posts: 9,022
    edited January 2013
    stubby wrote: »
    I'd love to hear the results...
  • thsmith
    edited January 2013
    stubby wrote: »
    We could do that. We would use the main system for that not the ofc rig.
  • stubby
    stubby Posts: 723
    edited January 2013
    thsmith wrote: »
    Sounds like fun! Dying to hear 90's on the tube rig. Say the word and I am there.
    SRS 3.1TL
    Anthem AVM2
  • thsmith
    edited January 2013
    Caps, resistors and spikes in and back together. Dynamat has not shown up yet.
    Initial impressions are a wider soundstage, about 2.5' on each side, maybe 1' more depth, top end is a bit forward than previous and definately more sparkle. Bass at first was muddy, then subduded and now starting to tighten up and have nice texture.
    All and all a well spent $120 and a nice improvement from the get go.
    I know it gets even better from here.
    Stubby, I think my wife is planning a trip to Plano soon and that may be best time. But for sure we need to do this.
    Here are the before and after parts used.
  • thsmith
    edited January 2013
    I left the radio playing all night so the crossover has about 16 hours burn in and I am even more pleased. The top end is a bit relaxed now but the sparkle remains. Mid range has great presence and clarity. Bass is tight and punchy, something I never seem to get on FM radio but do now. I thought I might need to reposition them lastnight as they were still a tad muddy but not now.
    Playing Dire Straits BiAs SACD this morning. All I can say is beautilful ! The clarity is stunning.
    So, DKIP to answer your question on caps and resistor, the answer is yes it is worth doing.
  • stubby
    stubby Posts: 723
    edited January 2013
    Sounds like they're burning in nicely. So maybe they will be close to settled in by the time of the big comparo. I'll give you a ring later on this week to sort out the details.
    SRS 3.1TL
    Anthem AVM2
  • thsmith
    edited January 2013
    sounds good
  • thsmith
    edited January 2013
    Finished Dynamatting the LS90 drivers this weekend. Thought I would add some to the Pioneer Elite AV79.
    Caps are burning in nicely, the biggest change is the sound stage is opening up even more.
    Paul, I know I owe you a call. Being end of month there are quite a few conf calls trying to end the month on a high note. Next weekend for sure.
  • Hello. New member here resurrecting this old thread in the hopes of getting some advice.
    I've got pair of LS50s, still in mint condition, that I bought new in the early 90s and a pair of LS90s that I bought used in the late 90s. I'm refreshing the LS90s. I've bought upgraded caps and resistors thanks to this thread.
    When I bought the LS90s, the plastic frame that surrounds the grill had been sheared off. Most of the plastic pegs that hold in place had also been sheared off, so I reattached it with little globs of epoxy putty where each peg was (pic attached). For this refresh, I'd like to fill the frame with something to make it solid and also give me more surface area to adhere better to the speaker baffle. At first I was thinking of filling the entire frame with epoxy putty, but then I realized it would probably be easier to use liquid type epoxy that I could just pour in and let cure? Anyone have any advice or experience on what to use or how to go about this?
    Thanks much!
    TL/DR: I'd like to fill the frame (see pic) with something to make it solid and also give me more surface area to adhere better to the speaker baffle.
  • BlueFox
    BlueFox Posts: 15,250
    xschop Posts: 5,411
    2-part high flow epoxy or polyurethane would work.
  • tompat
    tompat Posts: 1
    z0rchy wrote: »
    Thanks much!
    I did this recently but I used a tube of construction adhesive by filling up the channel then taping it place and let sit overnight. It's stronger than when they were new
  • bhtoque
    bhtoque Posts: 0
    My 90's were already done with Dayton caps, Mills resistors and Jantzen air core inductors when I bought them last year. Love 'em! I can probably pull the c/o's and take photos if you need them...
    Would you happen to have parts list for what you used?
    pitdogg2 Posts: 27,317
    bhtoque wrote: »
    In case you missed it his post was from 2013 so that means he bought them from the seller in 2012.
    As stated he didn't do the work the original seller he bought them from in 2012 may have done the work.
    xschop Posts: 5,411
    Those drivers would also benefit from Gstater's inner frame foam mods.
