RTA 11TL's - what do I need to know
EndersShadow
EndersShadow Posts: 17,732
edited July 2013 in Vintage Speakers
So I am going to be picking up the RTA 11TL's dracoskeeper listed to use in place of my Polk Monitor 60's in my office. I have a very small space measuring 10x11. The plan is for these to be in the corners on the 11' wall.
Is there anything I need to be aware of regarding these speakers setup wise? I cant move them out too far into the room from the wall and have maybe 6 inches to play with there.
Do these normally require toe it, etc?
Just wanted to be ablet to set these up as quickly as possible so I can get maximum listening time on em the day I pick em up :smile:.
Post edited by EndersShadow on
  • Mystery
    Mystery Posts: 2,546
    edited January 2013
    edited January 2013
    Are the 11TL's 6 ohm or 8 ohm speakers? I was assuming they were 8 as thats what Polks site lists em at but I am finding some references to them being 6 ohm.
    Also IIRC they can have RDO's installed (which I may or may not do). If this is the case which tweeter would I use and what are the costs for it?
    Obviously I wont know if I want to do the tweeter upgrade till I hear em, or I may do it just because depending on the cost.
  • smglbrth
    smglbrth Posts: 1,500
    edited January 2013
    The 11t's are 6 ohm, the 11tl's are 8 ohm. Wow, that's a small room for those...
    edited January 2013
    smglbrth wrote: »
    Good, I was hoping that would be the case. The tube amp can handle 6 ohms, but I prefer 8 ohms so I dont stress it at all...
    smglbrth wrote: »
    Yes it is, but its what I got for now. I can always carry em downstairs if I wanted to (when the wife is out and about).
    I am hoping the 18-20 watts per channel of tube power will be enough to make em sound good.
    This rig will hopefully last for a long time....
  • 11tsteve
    11tsteve Posts: 1,166
    edited January 2013
    i like my 11T's slightly toed in. and my room is only a smidge larger.
    both are in corners, 6 inches off of each adjacent wall. my room is not ideal, but this seems to give me the best imaging and bass.
    i will be anxious to hear what you think. mine have a very large soundstage, and the tweets are a perfect height for me in a chair at my desk.
    Polk Lsi9
    N.E.W. A-20 class A 20W
    Keces DA-131 mk.II
    Paradigm DSP-3100 v.2
    edited January 2013
    Good to know Steve!
    PS here is my new listening chair
    It was custom made by one of my uncles last week. It's as sturdy as it comes! Almost untippable
  • 11tsteve
    edited January 2013
    almost, huh??? :cheesygrin:
    she's a beaut! your uncle has some talent.
    my room is also hard and untreated still. plaster walls, wood floors but a large center rig, and two office desks... i need to work on that next but have no idea where to start. i assume yours is more of a listening room?
    Polk Lsi9
    Keces DA-131 mk.II
    edited January 2013
    11tsteve wrote: »
    Yes yes he does! It made our week for sure!
    11tsteve wrote: »
    Eh, not really, it's got my desk and the digs cages in there but the middle of the room is open so I will prib keep the rocking chair where it needs to be and move my computer chair as needed.
  • smglbrth
    edited January 2013
    I've come to the conclusion that the only way you get a decent listening room is to build it yourself. In every house we've owned/lived in all the rooms left much to be desired. Not because of the treatments but because of the layouts, although the "decor" didn't help.
    Anyway, enjoy those 11tl's. I used to have a pair long ago, nice speakers as long as you don't push them like I did. Ah, the younger, more foolish days of youth. Blew all four drivers out of those...
  • skrol
    skrol Posts: 3,474
    edited January 2013
    That is a rather small room for the RTA11TL's as they do like some breathing room; not a show stopper though. I would toe them in a little to get the sweet spot where you are seated for listening. That power should be fine. Yes, they are 8 ohms. My RTA11TL's are able to fill my family room and kitchen (26' x 14') with full sound even at low volume.
    The RDO-198 tweeter is definitely a worthwhile upgrade as is upgrading the crossover caps and resistors. The sound stage becomes much more open and dimensional. Dynamat the MW and PR baskets too.
    Stan
    Main 2ch:
    HT:
    Other stuff:
    edited July 2013
    I realize this is a bump to an old thread, but I wanted to post this information here in case others found this thread later on.
    Here are some threads for reference:
    Pics of a 11TL crossover (kinda): http://www.polkaudio.com/forums/showthread.php?84490-Help-me-plan-troubleshoot-my-11TL-crossover-redo&highlight=11tl
    a 11T to 11TL mod: http://www.polkaudio.com/forums/showthread.php?7846-RTA-11t-to-11tl-upgrade-and-tweaks-final-assembly!&highlight=11tl
    link to the pictures of this mod: http://webpages.charter.net/btreinen/speaker_tweak.htm
  • codycatalist
    codycatalist Posts: 2,661
    I've been searching for some information on placement for my RTAs, finally found something! Thanks for starting this thread!
  • codycatalist
    Would you be able to take some pictures of the grills and measurements? Mine are missing and I am more than likely going to have to make some.
  • skrol
    skrol Posts: 3,474
    Do you have the T or the TL? I can take some pics and measures of my TL's if that is what you have. I think the grill for the T is different.
    I posted some info on the TL.
    stan
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • codycatalist
    Yeah I have the TL version. Thanks that'd be great!
    Just saw this. I've since parted with them so I can't get your measurements but I see someone else has got you covered.
  • skrol
    skrol Posts: 3,474
    I took some quick measurements. The inner edge of the top portion of the grill is rounded over to refuse refraction. [img]http://cd8ba0b44a15c10065fd-[/img]4xwmcs8pdxq0.jpeg
    24461f391e20b7336331d5789078af53.r23.cf1.rackcdn.com/polkaudio.vanillaforums.com/editor/os/hjur9l54u8sj.jpeg
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • codycatalist
    Dude....you're awesome.
    ^No joke. You couldn't ask for more than that.
