One dumb question
I just picked up a pair of Polk fxi a4's to serve as rears in a 5.1 system. They'll be mounted flush on a rear wall about 3' behind our seating area. My question is are they supposed to be mounted with the woofers firing in towards the seating area or out firing towards the side walls?
I liked the sound better when the woofers were facing me. Play around with both and see which sounds better.
Thanks Leroy. From a fellow Wisconsinites I might add. Racine for me.
Welcome to the forum.
They are marked on the rear left and rightHome Theater
Two Channel
Oppo 105D BAT VK-500 w/BatPack SDA SRS 2.3 Dreadnought Squeezebox Touch Apple TV -
I set mine at ear level with the woofers pointed toward the end of each side of the couch. Left side points to left side of couch, right side to right side of couch.---
Polk Studio Monitor 4.6 Series 2's, Polk RT1000p's, Polk LSi25's, Boston Acoustic VR-975's
Crown D-75, Crown CE1000, Crown CE2000 -
+1, my FXiA6's are labled L and R.
I just recently had mine located on the back wall behind the seating area and returned them to the sides. I certainly prefer the acoustics that way.
IMO, the surrounds seemed to overbearing from the rear and tend to blend more from the sides. Could just be my room.Marantz AV10-Emotiva ERC3-Denafrips Venus-Panasonic UB9000-AudioQuest Power Quest 707-Emotiva DR3, DR2, XPA2, XPA6-Focal Kanta No2, Sopra Center-PolkAudio RTiA9, RTiA3, LSiM 702F/X-Epik Empire-11.2 -
One dumb answer.... Where they sound good to you.If you can't hear a difference, don't waste your money.
Idealy they are supose to be on the side walls slightly behind you and a few feet above ear level.AVR: Onkyo Tx-NR808
Rear: FXI A4
Sub: Polk DSW Pro 660wi
TV: LG Infinia 50PX950 3D
IC: AudioQuest Black Mamba II -
Wouldn't that be if you had them set to dipole? I thought that the rule of thumb was dipole for side mounting and bipole if rear mounted.
