One dumb question
Upside
edited January 2013 in Speakers
I just picked up a pair of Polk fxi a4's to serve as rears in a 5.1 system. They'll be mounted flush on a rear wall about 3' behind our seating area. My question is are they supposed to be mounted with the woofers firing in towards the seating area or out firing towards the side walls?
  • leroyjr1
    edited January 2013
    I liked the sound better when the woofers were facing me. Play around with both and see which sounds better.
  • Upside
    edited January 2013
    Thanks Leroy. From a fellow Wisconsinites I might add. Racine for me.
  • leroyjr1
    edited January 2013
    Welcome to the forum.
  • zane77
    edited January 2013
    They are marked on the rear left and right
    Two Channel
  • KellyMic
    edited January 2013
    I set mine at ear level with the woofers pointed toward the end of each side of the couch. Left side points to left side of couch, right side to right side of couch.
    Polk Studio Monitor 4.6 Series 2's, Polk RT1000p's, Polk LSi25's, Boston Acoustic VR-975's
    Crown D-75, Crown CE1000, Crown CE2000
  • Geoff4rfc
    edited January 2013
    zane77 wrote: »
    +1, my FXiA6's are labled L and R.
    I just recently had mine located on the back wall behind the seating area and returned them to the sides. I certainly prefer the acoustics that way.
    IMO, the surrounds seemed to overbearing from the rear and tend to blend more from the sides. Could just be my room.
  • decal
    edited January 2013
    One dumb answer.... Where they sound good to you.
  • jbooker82
    edited January 2013
    Idealy they are supose to be on the side walls slightly behind you and a few feet above ear level.
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
    Sub: Polk DSW Pro 660wi
    TV: LG Infinia 50PX950 3D
    IC: AudioQuest Black Mamba II
  • Upside
    edited January 2013
    jbooker82 wrote: »
    Wouldn't that be if you had them set to dipole? I thought that the rule of thumb was dipole for side mounting and bipole if rear mounted.
