Placing CS2 Upside Down & Wiring Question
amgala
I feel like a newb (and I am since this is my first real foray into HT) but I recently read that you can turn a Polk CS2 upside down on the angled edge if the placement is below the TV, and that will angle the speaker up towards the listener. My question is, if I do this, do I need to reverse the L/R speaker wire plugs accordingly since they have swapped sides?
Front Speakers: Polk Audio LSi15 x 2
Center Speaker: Polk Audio LSiC
Rear Speakers: Polk Audio LSiF/X x 2
Subwoofers: Polk Audio PSW505 x 2
AVR: Denon AVR-3313CI
Amp: Emotiva XPA-5
Amp: Emotiva XPA-5
Post edited by amgala on
Thank you!Front Speakers: Polk Audio LSi15 x 2
Amp: Emotiva XPA-5 -
Connect red to positive, black to negative. No matter which way it is sitting.
Correct, and don't just flip it upside down. Make sure it is firing directly towards the main seating position.
If flipping it upside down angles it too high, then sit it normal and find something to prop the front of it directly towards the main position.2 ChannelTurntable - VPI Classic 2/Ortofon 2M BlueAmplification - Rogue Audio Cronus Magnum II, Parks Audio Budgie PhonoSpeakers - GoldenEar Triton 17.2 Home TheaterDenon AVR-X3300W; Rotel RMB-1066; Klipsch RP-280F's, Klipsch RP-450C, Polk FXi3's, Polk RC60i; Dual SVS PB 2000's; BenQ HT2050; Elite Screens 120"Man CaveTurntable - Pro-Ject 2.9 Wood/Grado GoldAmplification - Dared SL2000a, McCormack DNA 0.5 DeluxeCD: Cambridge AudioSpeakers - Wharfedale Linton 85th Anniversary; LSiM 703; SDA 2A -
Will do, thanks for the infoFront Speakers: Polk Audio LSi15 x 2
Amp: Emotiva XPA-5
