Placing CS2 Upside Down & Wiring Question
amgala
amgala Posts: 111
I feel like a newb (and I am since this is my first real foray into HT) but I recently read that you can turn a Polk CS2 upside down on the angled edge if the placement is below the TV, and that will angle the speaker up towards the listener. My question is, if I do this, do I need to reverse the L/R speaker wire plugs accordingly since they have swapped sides?
Front Speakers: Polk Audio LSi15 x 2
Center Speaker: Polk Audio LSiC
Rear Speakers: Polk Audio LSiF/X x 2
Subwoofers: Polk Audio PSW505 x 2
AVR: Denon AVR-3313CI
Amp: Emotiva XPA-5
Post edited by amgala on
  • ZLTFUL
    ZLTFUL Posts: 5,653
    edited January 2013
    Connect red to positive, black to negative. No matter which way it is sitting.
  • amgala
    amgala Posts: 111
    edited January 2013
    Thank you!
    Amp: Emotiva XPA-5
  • hochpt21
    hochpt21 Posts: 5,423
    edited January 2013
    ZLTFUL wrote: »
    Correct, and don't just flip it upside down. Make sure it is firing directly towards the main seating position.
    If flipping it upside down angles it too high, then sit it normal and find something to prop the front of it directly towards the main position.
  • amgala
    amgala Posts: 111
    edited January 2013
    Will do, thanks for the info
    Amp: Emotiva XPA-5
