A slightly different take on the Dreadnought
F1nut
For many years I wanted to upgrade the AI-1 SDA cable on my stock AI-1, but I wanted to keep the original pin/blade type terminal and socket because I never liked the idea of using binding posts for the connections. I don't know exactly why, I just didn't. I looked and looked for something that would work, but never did find anything. Along came the Dreadnought. I liked the idea of using a better isolation transformer, but still didn't want to use binding posts, so I did nothing. Then at one point another Polkie and I were looking at having new pin/blade terminals made, but that never panned out. When the 1000V Avel deal came up I knew it was time to abandon my hope of finding a pin/blade type terminal and look for something else. I found the Neutrik Speakon connectors and decided that is what I would use.
Since I use the excellent MIT Shotgun S1 cables I wanted to use the same for my new SDA cable. I talked with the good folks at MIT about this and they didn't think their cables with the network boxes would be a good idea as those boxes are directional. They suggested using the Shotgun cable without the boxes, so I acquired 16 feet. They warned me that this cable was a pain to terminate and they were right. The guts are not simply your typical stranded wire and that's probably all I should say about that. I have to thank the good folks at MIT for making this possible, thank you!
So, with the cable decided on I made very careful measurements to find out which of Neutrik connectors would work. I found that the NLT4MP-BAG female chassis socket would just fit between the upper Cardas binding posts on my 2.3TL's in place of the stock pin/blade socket. I chose the NLT4FX-BAG for the male end. As the MIT cable measures 21mm in diameter and the maximum inside diameter at the tail end of the NLT4FX-BAG shell is only 16mm I had to remove the rubber bushing, the metal ring that holds it in place and the plastic locking device inside the shell. That still wasn't enough, so I had to use my Dremel to enlarge the end of the shell. Let me tell you that was a lot of work. Things went very smoothly after that and the cables were done.
Needing an enclosure for the transformer I looked around and found something I liked from a company in China, but their stock sizes weren't what I wanted or needed, so I asked about custom sizes to which they said sure. After sending them my drawings they got back to me saying sure, no problem, but we have a minimum order of 10 for custom work. Since I didn't need 10 I dropped that idea and looked elsewhere. I talked with a certain someone (THANK YOU!) that was willing to make me a one off and placed the order.
The work on the binding post plate to accommodate the Neutrik chassis socket was a bit tricky because it's a one shot deal, but all went smoothly and installing the Avel in the enclosure was straight forward. I'm leaving out some of the finer details in this project, but I would suggest that one should have a certain level of knowledge, the right tools and the skill set required before tackling such a project. If anyone has specific questions, I would be glad to help.
I would like to thank all those that have gone before me on similar projects. You shared your knowledge, experiences and gave me ideas to work with. You guys make this forum the best around.
Oh yeah, sounds GREAT!!!
Both cables finished.
Close up of the Neutrik connector.
The Neutrik chassis socket installed. MIT jumpers, of course!
I tried black cap screws first....nah
With stainless steel cap screws.....much better.
The cover lined with Dynamat.
The guts. Stainless steel hardware was used to attach the transformer.
Behind the antique table I use for my gear.
Damn, she's pretty.
Damn, she's pretty.
Post edited by F1nut on
Looks fantastic Jesse! What do you think of the sound of the Dreadnought itself? That is imaging, soundstage, detail, etc? Thanks for sharing this.
"Have A Little Faith! And Everything You'll Face, Will Jump From Out Right On Into Place! Yeah! Take A Little Time! And Everything You'll Find, Will Move From Gloom Right On Into Shine!"- Arthur Lee -
well someone just raised the bar! Atta'boy Jesse.JC approves....he told me so. (F-1 nut)
Very nicely done.
I'll be doing something similar but with a different MIT cable that works with what I'm currently running. Unfortunately I have to use binding posts on the case. I'm not to particular for that though.
Nice jumpers too. -
A beautiful job, Jesse! Nicely done!
That's great looking stuff man.
The shotgun cable had to be a bear to work with.
what are the jumpers made from?Main Rig-Realistic AM/FM Record player 8 track boasting 4 WPC
I’M OFFENDED!!!! -
Excellent ! Nice work Jesse.Speakers: SDA-1C (most all the goodies)
Those are Shotgun jumpers. They do make jumpers for their stuff you just have to call and custom order them. With that said they only make jumpers for their higher end speaker cables, no no jumpers for any EXp folks :sad:"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
Nice!!! I am so making these changes!!!
Great job Jesse!! -
Outstanding! Welcome to Club Dreadnaught!Good music, a good source, and good power can make SDA's sing. Tubes make them dance.
M'eh, it's ok.
Just kidding, good work as always my friend!Wristwatch--->Crisco -
Nice work Jesse.
I'm curious though, what don't you like about using spades for the AI-1 cable?"Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer -
Beautiful work. We are lucky to have a genius among us! Can only imagine the crazy sounds coming from any of your systems!!"if it's not fun, it's not worth it & remember folks, "It's All About The Music"!!
I really hate you SDA guys...makin' me want a pair of my own so I can create beautiful Toroidal artwork too..."Some people find it easier to be conceited rather than correct."
"Unwad those panties and have a good time man. We're all here to help each other, no matter how it might appear." DSkip -
Nice job Jesse!"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Oh yeah BTW nice looking case!! Who made that for you?? LOL!!:cheesygrin:
Looks great Jesse!!! Top notch. Looks like McLaren made it.I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D
Thanks Greg.
Yes, it is all there better than before.brgman wrote:what are the jumpers made from?
MIT's, of course.drumminman wrote:I'm curious though, what don't you like about using spades for the AI-1 cable?
Spades always come loose, always. The only reason I'm using spades on the jumpers is because my speaker cables use bananas. Every once in a while I check the spades and sure enough, one or two will be loose and believe me, I torque the hell out of 'em.Toolfan66 wrote:Oh yeah BTW nice looking case!! Who made that for you??
Yeah, I wasn't sure you wanted me to say. Folks, Larry made the case and the faceplates.MillerLiteScott wrote:Looks like McLaren made it.
LOL.....Yep, Larry McLaren.Political Correctness'.........defined
President of Club Polk -
Excellent work Jesse, as usual.Spades always come loose, always. The only reason I'm using spades on the jumpers is because my speaker cables use bananas. Every once in a while I check the spades and sure enough, one or two will be loose and believe me, I torque the hell out of 'em.
You might want to look into AudioQuest spades. Mine have never became loose, even with very heavy speaker cables pulling on them. I always have to use a wrench to loosen the Cardas posts when I want to remove them. If this is something you want to pursue, AQ is good about making product recommendations for specific applications.Proud and loyal citizen of the Digital Domain and Solid State Country! -
Very nice F1! I have heard that Dreadnoughts improve the sound of SDAs over using stock or aftermarket SDA cables even when using common ground amps where a Dreadnought is not needed. Is this correct and if so what kind of improvements did you notice? I've been debating for some time on trying one with my SDAs using common ground amps.
I built an 800VA Dreadnought and used it with a common ground amp. After a period of burn in (maybe 25-50 hours) the improvement was easily audible: music seemed to float in the air instead of coming from the speakers. More like live performers in the room. Instruments were clearer especially in complex passages, better transients, more tactile bass.
Do it - I'm betting you'll love it. Avel Lindberg sells the 800VA transformer off the shelf too.
If you search the forum you'll find some great "how to" posts."Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer -
The Dreadnaught definitely produces an improvement over a straight SDA connection when used with a common ground amp.Good music, a good source, and good power can make SDA's sing. Tubes make them dance.
drumminman wrote: »I built an 800VA Dreadnought and used it with a common ground amp. After a period of burn in (maybe 25-50 hours) the improvement was easily audible: music seemed to float in the air instead of coming from the speakers. More like live performers in the room. Instruments were clearer especially in complex passages, better transients, more tactile bass.The Dreadnaught definitely produces an improvement over a straight SDA connection when used with a common ground amp.
This is all in your mind...placebo effects.Proud and loyal citizen of the Digital Domain and Solid State Country! -
Just like cables.Good music, a good source, and good power can make SDA's sing. Tubes make them dance.
Well, at least the Dreadnought "looks good" though.:rolleyes::razz:
Outstanding F1.
I've got my Dreadnought built (thanks Neil & Larry), but I'm mulling how to terminate at the speaker (currently updating CRS+'s). Will probably just default to Cardas spade. Wondering if I should, or even could, start breaking the DN in before speaks are done? It's KILLING me seeing the DN just sitting there.
Craigb]Beach Audio[/b]: Rega RP6 (mods) - AT33PTG/II - Parks Budgie SUT - PSAudio NPC * Eversolo DMP-A6 * Topping D90iii * Joule-Electra LA-100 mkIII * Pass Aleph 30 * MIT S3 * Polk SRS 2.3tl (mods) * PSAudio PPP3
Town Porch: WiiM Pro Plus * Sunfire Sig II * Canare 4S11 * Magnepan 1.6 * Dectet -
Great write-up and beautiful work, F1nut!Family Room, Innuos Statement streamer (Roon Core) with Morrow Audio USB cable to McIntosh MC 2700 pre with DC2 Digital Audio Module; AQ Sky XLRs to CAT 600.2 dualmono amp, Morrow Elite Speaker Cables to NOLA Baby Grand Reference Gold 3 speakers. Power source for all components: Silver Circle Audio Pure Power One with dedicated 20 amp circuit to main panel.
Exercise Room, Innuos Streamer via Cat 6 cable connection to PS Audio PerfectWave MkII DAC w/Bridge II, AQ King Cobra RCAs to Perreaux PMF3150 amp (fully restored and upgraded by Jeffrey Jackson, Precision Audio Labs), Supra Rondo 4x2.5 Speaker Cables to SDA 1Cs (Vr3 Mods Xovers and other mods.), Dreadnaught with Supra Rondo 4x2.5 interconnect cables by Vr3 Mods. Power for each component from dedicated 20 amp circuit to main panel, except Innuos Statement powered from Silver Circle Audio Pure Power One. -
Thanks for the great write-up. As usual Jesse, you have managed to raise the mark for the rest of us. Outstanding work! It's a shame it's hidden!Sunfire Theater Grand IV
SRS 2.1TL
SDA 2BTL's
CSiA6
FXiA4
FXiA6
SDA 2A's
Monitor 10A's
http://www.douglasconnection.com -
Thought I would post this pic here as well. My case is done except the transformer. It's on it's way!!
Thanks Jesse!!:biggrin: -
High marks Jesse! Love the Neutrik connectors. They got everything covered.Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 *
just to be clear . . you've got a 1KVA tranny on its way? . . . . . cuz I've got a spare, thoughts?
GAC Regenerator PS Audio PerfectWave Power Plant 10
Pre Cary SLP-05
Power Rogue M180 Dark monos
Mains Salk HT2-TL
Rythmik F12
