Technics SL-1350 left channel louder
jaycam
jaycam Posts: 100
edited January 2013 in Electronics
Last night I replaced the cartridge on my 1350. Went with the AT95e. It sounds great but the left channel is noticeably louder. My other sources are balanced and I tried a few records just to make sure it wasn't the record. Any ideas?
Post edited by jaycam on
    billbillw Posts: 8,108
    edited January 2013
    One channel is louder because the stylus is pressing into one side of the groove harder than the other. Check your alignment and/or anti-skate.
    Might also double check the cartridge leads. Make sure they are in proper phase as well.
  • thsmith
    thsmith Posts: 6,082
    edited January 2013
    Sounds like cart alignment or the side to side adjustment, cant think of the name at the moment. I think I am getting CRS. Cant remember sh..
  • thsmith
    edited January 2013
    billbillw wrote: »
    On channel is louder because the stylus is pressing into one side of the groove harder than the other. Check your alignment and/or anti-skate.
    Anti-skate, thats the name. Thanks Bill.
    edited January 2013
    Jay,
    Might want to read this and make sure you are doing everything correctly. Some of it is not intuitive. Took me a while to grasp all the concepts.
    http://www.audiophilia.com/features/cartridge_setup.htm
  • jaycam
    jaycam Posts: 100
    edited January 2013
    Thank you. I'll check the anti-skate tonight. I thought I had it set correctly. I set the balance and then the stylus pressure according to the specs for the cartridge. Maybe I went too far :-)
    The AT95e sounds much better than the Series V cart that was on there...even with the left channel louder :-p
