Best configuration for home-cinema theater 7.1
Hi everyone!
I would like to know which configurations with my receiver >AVR< would be the best for my home-cinema theater 7.1 with these speakers and receiver... My living room is about : 14?5? x 19?
Thank's:rolleyes:
R?cepteur: HARMAN KARDON AVR-354
75W/canal 20Hz ? 20kHz
Center: POLK AUDIO CSI3
2-5 1/4?driver & 1-1?tweeter
Overall frequency response: 55Hz-27kHz
-3db Limits (65Hz-26kHz)
Recommanded amplification: 20-180W/canal
Front: POLK AUDIO R30
1-6.5? mid/woofer & 1-3/4? tweeter
Overall frequency response: 45Hz-24kHz
-3db Limits (55Hz-20kHz)
Recommanded amplification: 20-150W/canal
Surround Front : POLK AUDIO RTI6
1-6 1/2? driver & 1 ?tweeter
Overall frequency response: 40Hz-27kHz
-3 db limits: (50Hz-26kHz)
Recommanded amplification: 20-125W/canal
Back Surround : POLK AUDIO RTI4
1-5 1/4 ?driver & 1 ?Tweeter
Overall frequency response: 50Hz-27kHz
-3 db limits: (60Hz-26kHz)
Sub-Woofer: POLK AUDIO PSW10
1- 10?
Overall frequency response: 35Hz-200Hz
100W (50W RMS)
Thank's:rolleyes:
1- 10?
100W (50W RMS)
Post edited by Luce on
From what I hear, the PSW10 is a bit weak
what i would appreciate to have for answers is which 'SETTINGS' could help me to be the best configuration with my harman kardon receiver with those speakers...
thank's again -
Thank your for your advisement but for the moment, it is the subwoofer that I have and it's not so bad to listen... maybe i will change it in the future but actually i will keep it
You shoud start with allowing the AVR to run its auto-cal program, think it uses Audessy, and then listen to it a few times to find the weak areas, if any. If you wish to manually set the cross-over freqs, start at 80Hz, and adjust from there.
Thank your for the info... In the menu config of my Harman Kardon, it could be readed like that? -
Somewhere in the menu setting of the receiver you'll find the option to set crossovers for the speakers. Set those to 80HZ which the standard these days. Also most likely the receiver will set your speakers to LARGE or Full Range, change that option to small and let the sub handle all the low bass frequencies. Hope this kind of helps.Front- RTI A7,(powered by ADCOM GFA 5500)
Center- CSI5,
Surrounds- RTI 6 and Rear Surrounds- TS 15.
TV-Panasonic P55ST50
SUB-SVS PB10-NSD and PSW505
Receiver- Yamaha Aventage RX-A2000 -
Ok... have you seen by photos... it's all i can find in my menu and the other photo is behind my sub-woofer... is it the good?
