Would you set your CS20 to Large of Small on your receiver?
buckrogers
buckrogers Posts: 11
edited January 2013 in Speakers
Hi, I have two Tsi300 speakers, one low-end Yamaha subwoofer, and a CS20 speakers.
What should I put my receiver to? Large or small? I read if you do small it sets the crossover at 80hz but if you put large the bass goes to the regular speaker. I kind of like large myself. Is that because my subwoofer is sub-par (it is I know, a htib leftover).
Thanks.
Post edited by buckrogers on
  • cowtrimmer
    cowtrimmer Posts: 201
    edited January 2013
    I would set it at whichever one sounds better to you. A better sub in the mix will free up that center speaker for what its designed to do and not be a large bass source.
  • bansheesho
    bansheesho Posts: 227
    edited January 2013
    Do what sounds best. Try both out and see what you like best. For my setup with my ears I prefer large for the front three speakers and small for the rear. I find that seeing a crossover at 80hz makes content sound thin.
    Give each setting a fair trial then decide. If it's available as an option you might also try lower crossover points too.
    Pioneer SC-25 | Adcom GFA-555 | KEF q900 Front | KEF q600 Center | Polk Monitor 30 Rear | Polk CS2 Rear Surround | Polk DSWPRO 660wi sub
  • mantis
    mantis Posts: 17,388
    edited January 2013
    Small , it doesn't have the ability to play full range. Let the sub do everything under 80hz. Most speakers in a home theater setup should be in small. This gives you the best dynamic range and clarity.
    Dan
    tonyb Posts: 33,072
    edited January 2013
    buckrogers wrote: »
    Thanks.
    Which ever sounds best to you in your environment. There are no absolutes. Given you have a HTIB sub, it can't play that low anyway. Are your speakers hooked up to the receiver or the sub ? Just be carefull with that volume dial if you set the center to large.
  • buckrogers
    edited January 2013
    tonyb wrote: »
    What can happen? Will it blow up the driver?
  • Lietuvis91
    Lietuvis91 Posts: 909
    edited January 2013
    I feel like i've tried it all, and what's actually pretty fun is if you have gobs of power from a beefy amp it's actually kind of fun to set the center to large and have it produce the full range. My CS2 puts on a quiet a slamin' show with action flicks when I feed it 400watts by an hca1000 bridged. You really do get the feeling like you're in the middle of it all, and it honestly can get to be too much even.
    However, with most run of the mill avrs, centers set to large don't get even close to getting it done in the low end and it just muddies up the sound, particularly speach. So, give both a try, if you like, but my bet is you'll like "small" better. Just better clarity and detail and the sub is better at handling low end anyway.
    Living Room 7.1 HT Rig:
    M70 | CS2 | M60 | Atrium5 - Surr. | SUB - Emotiva ULTRA12 + Tara Labs sub cable | Pioneer Elite VSX-52 | Parasound HCAs 1000A | Sony BDP-S790 | Belkin PureAV PF60 | MIT Exp2 Wires
    Bedroom 5.0 HT Rig (Music/Movies/Gaming) :
    LSi9 | LsiC | Lsi/fx | Marantz SR7002 | NAD T955 | Sony BDP-S360 | Belkin PureAV PF30 | AQ Blue Racer II ICs & AQ Type 4 wires | PS3
  • PubFiction
    PubFiction Posts: 105
    edited January 2013
    You should set it to small if you have a sub and large if you do not. If you have a ton of power in your amp I suppose you could set it to large with a sub, but it you would need to re balance everything / re run room correction. Most people cannot get their sub to do much of anything if they have speakers set to large which then wastes your sub, but you arent going low with the CS2 so you need the sub anyway.
    The other option is just to set the crossover point for LFE very low like 40-50 hz on the receiver.
  • Csa73
    Csa73 Posts: 36
    edited January 2013
    Thanks for the link pearsall001. It helped me out.
  • kuntasensei
    kuntasensei Posts: 3,263
    edited January 2013
    PubFiction wrote: »
    Not picking on ya'... Just clarifying a common mistake that people keep making. There is no crossover point for LFE. LFE is the low frequency effects channel, not the redirected bass from other channels. The subwoofer output of your receiver combines the LFE channel with the summed bass content determined by the system crossovers to produce a total output to your sub. Some AVRs have a "LPF of LFE" control, but that should always be set to its maximum of 120Hz so it doesn't truncate the LFE channel (which is brickwall filtered at 120Hz anyway by design and mixers rarely put significant content over 80Hz there regardless).
    As far as the CS2 goes, if the receiver only has Large/Small, pick Small. The CS2 has a lower -3dB point of 60Hz and a natural rolloff around 55Hz. It is not made for full-range reproduction no matter how much power you can feed it and is perfect for the typical 80Hz crossover most AVRs use as "small". If your system has adjustable crossovers per-channel, I recommend setting the crossover around 10Hz above the speaker's -3dB point and trying that (which would be 70Hz in your case). That gives you a little room for the speaker-to-sub transition to occur before the speaker's natural rolloff kicks in.
    If you're not happy with the bass in that configuration, I recommend saving up for something better than that HTIB sub. :wink:
    Equipment list:
    Onkyo TX-NR3010 9.2 AVR
    Emotiva XPA-3 amp
    Oppo BDP-93 Blu-ray player
    Epson 8500UB 1080p projector
  • buckrogers
    edited January 2013
    On my receiver, Yamaha HTR-5930, It only has a +- scale for LFE. I'm not sure what to put there.
    edited January 2013
    I run a CS2 in one of my systems and it depends on the room. But 60 (it's natural roll off point) to 80hz is the range I would experiment with until you see what sounds best to "you". That could be 60, 70, or 80hz.
    As mentioned above, there really are no absolutes here. And what you here is the baseline!
    The +/- you're seeing is probably loudness levels for the SUB channel. Perhaps in a range from -20db to +12 or something like that. That IS NOT the crossover, but allows you to increase or decrease the volume level of the sub channel in relation to the others!
    Have fun tweaking!
    cnh
  • mantis
    edited January 2013
    Set the center channel to small , 80hz crossover to the sub. If your sub is not up tot the task , do yourself a huge favor and save up for a good quality sub. If you need suggestions , please list your entire system , room size , uses etc.
    Dan
