Monitor 70 series II , Cs2 Need rear surrounds ( R300) ?
lerbe631
lerbe631 Posts: 3
edited January 2013 in Speakers
I already have Monitor 70 Series II for the fronts, A CS2 for the center and am currently running some generic speakers as surrounds. I Saw that R300 speakers are on sale for $50 am wondering if they will voice match my current speakers ? Even if they are close I will probably buy them.
Any answers will help thank you
Luke
  • michael1947
    michael1947 Posts: 775
    edited January 2013
    WELCOME :razz:My opinion only is that rears and sides are far less important than the front 3, which should be matched. For rears I see no problems with non-matching fronts as long as the impedance is matched with your AVR. good luck
    Main Family Room: Sony 46 LCD, Sony Blue Ray, Sony DVD/VCR combo,Onkyo TXNR 708, Parasound 5250,
    Living Room: Belkin PF60, Parasound HCA2200, MIT ProlineEXP balanced IC's,Emotiva XDA-1 DAC/Pre,Emotiva ERC2 transport,MIT AVT2, Polk LSI 9's.
  • cowtrimmer
    cowtrimmer Posts: 201
    edited January 2013
    Monitor 30's on stands if your looking for floor models maybe?
  • BigDaveyL
    BigDaveyL Posts: 36
    edited January 2013
    cowtrimmer wrote: »
    +1
    The Monitor 30's will be the perfect match as well as the 40's.
  • lerbe631
    lerbe631 Posts: 3
    edited January 2013
    Thanks for the quick replies
    edited January 2013
    Welcome to Club Polk!
    Mike1947 has you covered above. NO problem throwing a couple R300s back there. I doubt you'll be able to even tell a difference!
    cnh
