Monitor 70 series II , Cs2 Need rear surrounds ( R300) ?
I already have Monitor 70 Series II for the fronts, A CS2 for the center and am currently running some generic speakers as surrounds. I Saw that R300 speakers are on sale for $50 am wondering if they will voice match my current speakers ? Even if they are close I will probably buy them.
Any answers will help thank you
Luke
Luke
WELCOME :razz:My opinion only is that rears and sides are far less important than the front 3, which should be matched. For rears I see no problems with non-matching fronts as long as the impedance is matched with your AVR. good luckMain Family Room: Sony 46 LCD, Sony Blue Ray, Sony DVD/VCR combo,Onkyo TXNR 708, Parasound 5250,
Living Room: Belkin PF60, Parasound HCA2200, MIT ProlineEXP balanced IC's,Emotiva XDA-1 DAC/Pre,Emotiva ERC2 transport,MIT AVT2, Polk LSI 9's. -
Monitor 30's on stands if your looking for floor models maybe?
cowtrimmer wrote: »Monitor 30's on stands if your looking for floor models maybe?
+1
The Monitor 30's will be the perfect match as well as the 40's. -
Thanks for the quick replies
Welcome to Club Polk!
Mike1947 has you covered above. NO problem throwing a couple R300s back there. I doubt you'll be able to even tell a difference!
