Kenwood KC-105 and KM-105 Amp and Pre-Amp
xjghost
xjghost Posts: 1,115
edited January 2013 in 2 Channel Audio
Ok I found this set on ebay for $129.00 + shipping. Woudl these be a good set to use tem till I can find something more to my liking? Are these decent for that money? I just want something more powerful then the Denon 5.1 I bought last year that is a major dissapointment in teh music listening to department.
HT/2Channel: Emotiva MMC-1, Adcom GFA-555II, Polk SDA 3.1's, Teac TN-300 TT, Polk Center and Sub.
Bedroom system: Carver CT-24, Parasound HCA-800II, Monitor 10's
Additional projects: RTA 12c's
Post edited by xjghost on
  • George Grand
    George Grand Posts: 12,256
    edited January 2013
    Those two pieces are toys. I wouldn't be surprised to find an "8 OHMS MINIMUM" stamped near the speaker spring clips on that amp.
  • michael1947
    michael1947 Posts: 775
    edited January 2013
    Oh, not so fast Grasshopper. I just checked one of my several old Kennys and it says 8-16 ohms under the spring clips, and pretty much everything back then had spring clips.
    1. They are separates.
    2. They have excellent specs.
    3. They are readily available which speaks to their Japanese build quality and longevity.
    4. They can be had for about 1/2 the price of decent speaker cables today.
    5. I still own at least 4 and use them as fill ins and dust magnets.
    For me, I still have a fondness for my old Kenwood stuff as it was my first upgrade to separates 25 years ago and they're still going strong. I only have 1 of the 105 series most of mine are 205,208's which run 150 wpc and a M1.
    For the bucks I say give the old Kennys a hard look and think of 150wpc models.:loneranger:
    Main Family Room: Sony 46 LCD, Sony Blue Ray, Sony DVD/VCR combo,Onkyo TXNR 708, Parasound 5250,
    Living Room: Belkin PF60, Parasound HCA2200, MIT ProlineEXP balanced IC's,Emotiva XDA-1 DAC/Pre,Emotiva ERC2 transport,MIT AVT2, Polk LSI 9's.
    mhardy6647 Posts: 35,374
    edited January 2013
    George is right about these. I wouldn't call them junk but they are not serious hifi hardware.
    A pair passed through my abode some years back; search at AK and you'll find a few tidbits.
    edited January 2013
    Kenwoods? You really want some old silver face integrateds (preferably the Dual Power models). Also fairly available. Not too expensive and nice neutral to slightly warm sounding with good "power"!
    Although, if you just want some "power" for a pair of speakers and you need it "now", I suppose these Kenwoods are not horrible. I have an old ('89) Kenwood surround receiver. It weighs about 35 lbs. Can put out a legitimate 130 watts x 2 at 8 ohms, can power 4 ohm loads but only when it is "switched" (on back). It's crazy loud on 8 ohm speakers. But I wouldn't brag about its sound quality, a bit too bright and way too forward, but powerful.
    cnh
  • xjghost
    edited January 2013
    Thanks guys. I got bussy at work and forgot to check here and by the time I did they have sold. They sold for 129.00... IDK just looking right now. I have a Haffler 500 in the shop waiting on the verdict. It was given to me a while back and there is only one shop that I can find in teh state of South Carolina, where I live, that will even look at this old stuff. Thanks I'm still looking. Found out a local pawn shop has a Adcom GFA-555II on the shelf. Going to call him back and see what kinda "deal" he is willing to make on it.
    edited January 2013
    That Hafler should have a "warmer" signature than the Adcom. But the Adcom is a very neutral sounding and very "reliable", powerful amp that can run most systems without breaking a sweat. Both are good power amps, certainly better than the Kenwood you posted above!
    Good Luck!
    cnh
    edited January 2013
    The Hafler is a good amplifier.
    For some more opinions (mostly positive) on the Kenwood amp(s), the OP might want to look at this thread at AK:
    http://www.audiokarma.org/forums/showthread.php?t=284089
  • michael1947
    edited January 2013
    Yup, now everyone's on the right path. If you want loud, fairly reliable and mostly cheap the Kennys are a good choice. With the Hafler and Adcom you've moved smack into the middle of hi-fi?
    edited January 2013
    Sums it up nicely.
    Adcom would be a better choice given your circumstances. If you plan on using an amp with the Denon, make sure it has preouts to even be able to do so.
  • xjghost
    edited January 2013
    I plan on picking up a preamp. The shop working on the Hafler actually has a Hafler pre amp for $140. They have an adcom for $199, which I think is a little high, but depending on what is up with the hafler I plan to have it fixed. It powers on but there is no response on the RCA's. They side there might be in internal fuse or the RCA's might be loose. I hope its something that simple. I talked to the shop about the Adcom and he will sell it for $200. So I'll make my decision next week. Hell I might go get the adcom anyway even if they fix the Hafler. Two middle of the road amps cannot be all bad?
    edited January 2013
    I like the Hafler preamps (FWIW)...
  • George Grand
    edited January 2013
    Not so fast? Check your math genius. 8-16 ohms KIND OF INDICATES no less than 8 ohms. You don't want to be sounding like an idiot Grasshopper.
    edited January 2013
    Just my opinion, but when talking seperate amps, if it isn't rated for 4 ohm use then it isn't worth more than a door stop and a waste of coin.
    edited January 2013
    Not so fast? Check your math genius. 8-16 ohms KIND OF INDICATES no less than 8 ohms...
    Ten-four; a direct coupled soiled state amp will be loafin' into a 16 ohm load. In to 4 ohms, not so much.
    tonyb wrote: »
    Just my opinion, but when talking separate amps, if it isn't rated for 4 ohm use then it isn't worth more than a door stop and a waste of coin.
    Only if one's loudspeaker load requires that kind of current capability.
    Unqualified blanket statements/generalities/opinions are, I'd opine, as inadvisable in hifi as in most other facets of debate.
  • xjghost
    edited January 2013
    I'm not technical at all. Looking into something that will power my Monitor 10's that I bought new in '88 or so. These things survived 4.5 years of college, twinn boys that are now 14 and multiple moves. I think I wnat to find some maller ones for my rear channels.... lol!
  • michael1947
    edited January 2013
    Now George is this any way to act on a forum where we all seek information from each other. Calling me names and the general disparagement of your remarks all for a difference of opinions? My, my, you seem to be bitter about something and it's probably not the Kenwoods or the little spring clips.
    You seem to be a heavy hitter on this forum and I'm confident you have earned the respect of your peers here but maybe you need to re-visit the purpose of this forum which from my point of view is to help others and not-so-much to ridicule those of contrasting views. You have taken this thread from fun and informative and turned it into a personal vehicle with which to boast your self imposed prowess as king of the audio world. I was planning to stop here and close with some appropriate suggestions as what you could do with your opinions but I didn't want to go down to your level so I'll just comment on my remarks.
    Your first response to the poster was very short calling his choice of an upgrade "toys." With the second statement where you refer to the ohm load and spring clips to me seemed like sarcasm to reinforce your disdain displayed in your first statement. While those two little sentences from you quite nicely summed up your feelings for the Kenwoods I didn't think it was very helpful to the one asking for help.
    It may have been useful to the new guy if you had explained the function of ohms in our audio world or the differences between 5-way and spring clips. To me the poster was a young person with only about 10 posts at the time wanting information about his potential purchase. I doubt that he has much knowledge of ohm loads nor the history of spring clips. I thought I would respond with some factual information thus I posted the exact information from under the spring clips(and although I am not at the genius level my math skills are quite good) and then I went on to defend the spring clips a little indicating that most consumer grade hi-fi equipment of that era had spring clips. My intention here was to tame down your rather brusk comments with something I thought was useful to the new guy.
    Well George I may be an idiot so I won't say any more except maybe this quote: Man becomes great exactly in the degree in which he works for the welfare of his fellow-men.
    Mahatma Gandhi:idea:
    edited January 2013
    My good man, take it in context to what the OP is doing. Moving from an AVR...which handles 8 ohm loads, to a seperate amp which may only handle 8 ohm loads, is what most would consider a lateral move. Nothing, unqualified or general about it.
  • PolkMaster1
    PolkMaster1 Posts: 847
    edited January 2013
    Sopshigo wrote: »
    During the last 9 weeks, you might have adored and guarded your child inside the womb. Seeing that she is out in the planet, you must do your very best to keep the girl safe and comfortable. You have probably currently baby-proofed your own home, yet what about the girl baby's room? Think about your ex baby crib?
    Whilst you may think in which pads, comforter covers, as well as lush toys and games leave her with comfort while she's in their own child's crib, these apparently benign products can in fact enhance ćwiczenia na uda i pośladki the girl probability of Sudden infant death syndrome (sudden infant death syndrome). They boost her chance of suffocation.
    Sudden Infant Death Syndrome boasts approximately A couple of,500 toddlers every year. In reality, it does not take primary source of death regarding infants under one year old. Sadly, researchers have no idea what causes SIDS, however they possess specific risk factors in which put your baby prone to death using this syndrome.
    As a looking after parent, you should safeguard your child through Cot death syndrome at all that one could. This can be achieved through making sure that the woman's baby crib and your ex crib bedding established feel at ease , nor create any kind of hazards.
    Is Your Baby's crib Installed Effectively?
    To look for the basic safety of the child's crib, you should be sure that the particular baby crib is effectively set up high aren't absent pieces that may lead to entrapment or perhaps suffocation. Children have died of their baby cribs after their particular mind or necks grew to become entrapped inside the spaces of the child's crib, on account of broken slats and also absent hardware items. Consequently be sure that your crib is properly installed as well as stable.
    Are There Any Missing or even Broken Vanes?
    Just before using any baby crib, you have to make certain that there isn't any missing out on, drop, as well as busted gry przegladarkowe slats. There shouldn't be greater than Only two as well as 3/8 inches wide (the particular thickness of a can involving soda pop) between the vanes. You do not want to threat the chance your newborn can by accident tumble over the panels.
    You should also make certain that there isn't any cutouts in a choice of the particular queen headboard or perhaps the footboard from the baby's crib. You do not need kids visit acquire stuck.
    Your Crib's Bed
    When choosing any mattress to your baby's crib, don't use delicate mattress. It's a good idea to your newborn to sleep on a firm bed mattress. It's also advisable to be sure that it is just a tight-fitting bed mattress. This will make sure that your newborn can not acquire stuck involving the baby crib as well as the bedding.
    To hold child safe and sound any time jane is asleep, you ought to only use a new fitted baby's crib bed sheet that is certainly created specifically for your crib. Avoid the use of bedding which are not designed for the baby crib. These are often too unfastened as well as not well installing, and so they can lead to suffocation.
    What the hell does this have to do with Polk Audio? None of your posts belong in this forum.
    Statistics show that 98% of us will die at some point in our lifetime.
    The other 2% will work for WalMart.
