pc as my source
IMO the sound quality of JRiver is leaps and bounds better than Mediamonkey. I used mm for quite a while. In addition, you have so many more options for organizing and customization. Consider it does bit perfect ripping, file conversion and has the option of room correction. You do get quite a bit of value for $50.falconcry72 wrote: »In a different league in what way? Media management or sound quality? -
IMO the sound quality of JRiver is leaps and bounds better than Mediamonkey...
My question was a bit rhetorical about sound quality because if you're using a bit-perfect playback method, i.e, WASAPI or ASIO, how could the sound quality be any different at all? Not talking about features here, just SQ.2-Channel: PC > Schiit Eitr > Audio Research DAC-8 > Audio Research LS-26 > Pass Labs X-250.5 > Magnepan 3.7's
Office: Phone/Tablet > AudioEngine B1 > McIntosh D100 > Bryston 4B-ST > Polk Audio LSiM-703's -
The driver is just an interface, there are still other things going on in the software that can affect sound.falconcry72 wrote: »My question was a bit rhetorical about sound quality because if you're using a bit-perfect playback method, i.e, WASAPI or ASIO, how could the sound quality be any different at all? Not talking about features here, just SQ.
I can't comment on the two programs here, but on the Mac platform I have Amarra, BitPerfect, and Audirvana Plus all that send bit perfect data into my DAC and all sound very different.
I think the phrase bit perfect is thrown around too loosely, I don't know that there is such a thing and if there is I don't know how we can know for sure that it exists.
How's that for some Friday morning existentialism for ya... -
falconcry72 wrote: »So Face, have you found the DSP's or EQ's in JRiver to hurt SQ (aside from bad settings lol).
Configured correctly, only an increase.AsSiMiLaTeD wrote: »I think the phrase bit perfect is thrown around too loosely, I don't know that there is such a thing and if there is I don't know how we can know for sure that it exists.
AFAIK, bit perfect=asynchronous."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
AsSiMiLaTeD wrote: »The driver is just an interface, there are still other things going on in the software that can affect sound.
hmm. shows what I know!2-Channel: PC > Schiit Eitr > Audio Research DAC-8 > Audio Research LS-26 > Pass Labs X-250.5 > Magnepan 3.7's
Ok Mr. Face, I got another one for you:
I am currently using a 1.0 ohm resistor in the tweeter attenuator portion of the crossover on my 3.7's. Do you think that digital EQ'ing at the PC would be even less obtrusive to SQ; meaning, would I be better off putting a good jumper in the tweeter attenutor spot and addressing frequency response issues up front on the PC???
TLDR: what degrades SQ more: a physical resistor in the crossover or digital EQ'ing at the PC level?2-Channel: PC > Schiit Eitr > Audio Research DAC-8 > Audio Research LS-26 > Pass Labs X-250.5 > Magnepan 3.7's
The DIY crowd have been reclocking I2S before handing it off the DAC to reduce jitter. They test for bit perfect but reducing jitter is the goal.
Mike, can you swap DSD channels in JRiver like you can in foobar? DSD swaps R and L channel from I2S. If you can do it in software, it saves a digital switching solution to correct the swap.Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
you guys got me so lost, lol i like the v-link 192 and am curious to know why FLAC is better than WMA if they are both lossless, an external DAC will come when i get my PC and my HK 3490 together, and i see a lot of people upgrade their units to a detachable, how simple is it to do that to my AVR, and for the present i will use a free service, and i see you guys are in a bit of disagreement to the best one is, but i think the suggested to me as being easiest to use will be a good way to familiarize myself with some of this stuff, thanks you guys, i will check out the shops in seatle suggested to me by zingo, to see if they have the v-link, and if they dont order one in march when my vacation is over2 Channel(work in progress):DAC: Schiit modi 2 uberAmp:Parasound 1200 MK IISub:RBH 1010-SEP Speakers: Monitor 5A peerlesscurrently running some krk rokit 3g since the HK pre outs died and i need to start breaking everything down to move in a couple monthsHeadphones:Source: tidalDAC: schiit modius epre: schiit sysAmp: AQ dragonfly black/ schiit magni2 Cans: Velodyne V-True, Grado SR225i, sennheiser x drop gaming headsetPC:DAC: schiit modius e(over spdif)pre: schiit sysspeakers: prenous eris 5 xtSub: Earthquake Sound MiniMe-P63most of my comments are passing on of info, im a noob, im just trying to help how i can, if im wrong or out of place to comment, dont hesitate to let me know
"WITH WILLING HEARTS AND SKILLFUL HANDS, THE DIFFICULT WE DO AT ONCE, THE IMPOSSIBLE TAKES A BIT LONGER, WITH COMPASSION FOR OTHERS. WE BUILD - WE FIGHT FOR PEACE WITH FREEDOM"Seabee Memorial, Arlington, VA -
Have you tried using the pure direct setting on the rx-v765? It should minimize the amount of processing that is done to the signal (unfortunately bass management is one of those things).
As far as I know there shouldn't be a difference between lossless formats, maybe other than cpu overhead and player compatibility. Converting between lossless formats shouldn't cause any decreases in quality. -
Since you plan on getting a DAC in the future, consider skipping the v-link and putting the cash toward a DAC that supports asynchronous USB. It seems to be a feature that is becoming more common in entry level DACs.
This is the route I would take also (and I did!). I have tried several in the $150-$400 range, and would highly recommend the Musical Fidelity V-DACII. To my ears, it is the best of the class.2.1: PC>Schiit Gungnir MB>Schiit Freya Noval>NAD C-270>Ascend Acoustics Sierra-1, HSU STF-2 5.1: HDMI Bitstream>Denon AVR-1910>polkaudio RTE55, CS350-LS, RT3, HSU STF-2, Visio M55-F0 -
sounds like a good plan to me, if others have tried it and liked it, i dont see why not2 Channel(work in progress):DAC: Schiit modi 2 uberAmp:Parasound 1200 MK IISub:RBH 1010-SEP Speakers: Monitor 5A peerlesscurrently running some krk rokit 3g since the HK pre outs died and i need to start breaking everything down to move in a couple monthsHeadphones:Source: tidalDAC: schiit modius epre: schiit sysAmp: AQ dragonfly black/ schiit magni2 Cans: Velodyne V-True, Grado SR225i, sennheiser x drop gaming headsetPC:DAC: schiit modius e(over spdif)pre: schiit sysspeakers: prenous eris 5 xtSub: Earthquake Sound MiniMe-P63most of my comments are passing on of info, im a noob, im just trying to help how i can, if im wrong or out of place to comment, dont hesitate to let me know
I want to get more serious about building my music library on my PC and I see many recommendations for JRiver and a good DAC. If I am presently only using the sound card, does JRiver make sense? Also, I see recommendations against using JRiver for MP3's. Why?
StanStan
Main 2ch:
HT:
Other stuff:
Stan
I would think regardless of how your sending the music out JRiver would be a good choice. Your source file and playback program are the beginning of the chain, so if they are low quality, no matter what other gear you have upstream from it (soundcard, speakers, etc) wont make that big a difference."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
I have no idea why that would be. JRiver should be able to decode mp3 just as well as any other format.2.1: PC>Schiit Gungnir MB>Schiit Freya Noval>NAD C-270>Ascend Acoustics Sierra-1, HSU STF-2 5.1: HDMI Bitstream>Denon AVR-1910>polkaudio RTE55, CS350-LS, RT3, HSU STF-2, Visio M55-F0
Stan
Are people saying that JRiver is not good at playing MP3's, or that MP3's are not good to be played on JRiver? lol. The answer is that MP3's have no place in a hifi rig, period. But I agree with TBone, JRiver can play MP3's as well as any other media player.2-Channel: PC > Schiit Eitr > Audio Research DAC-8 > Audio Research LS-26 > Pass Labs X-250.5 > Magnepan 3.7's
Thanks for the clarification. I plan to convert CD's to FLAC but some music I only have in mp3 format (for now).Stan
Main 2ch:
HT:
Other stuff:
hey, it's better to have music as MP3 than not at all! I use MP3's in my car on my ipod, and stuff like that... but for the main rig? Lossless only.2-Channel: PC > Schiit Eitr > Audio Research DAC-8 > Audio Research LS-26 > Pass Labs X-250.5 > Magnepan 3.7's
I am in the same boat, some of the music I have in MP3 is the only format I can ever get it in as I have lost/discarded the original CD or never had it to begin with.
So in my main rig I have a combined library of all the CD's I did still have in FLAC, and now buy ONLY CD's to rip to FLAC so moving forward I am good. However I did add in all the compressed MP3's that I cant find elsewhere into that system simply because lots of those are songs I dont listen to critically but more for fun.
I mean who cares if you are listening to Nelly's Party People lossless or MP3 lol, either way your cranking it for the bassline and to nod your head and bounce along to the beat hehehe...."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
What do you guys use for ripping vinyl to FLAC?Stan
Main 2ch:
HT:
Other stuff:
i also still have a bunch of music in mp3 or other compressed type files, but i have a playlist composed of all my lossless files and one of the stuff i like the most,2 Channel(work in progress):DAC: Schiit modi 2 uberAmp:Parasound 1200 MK IISub:RBH 1010-SEP Speakers: Monitor 5A peerlesscurrently running some krk rokit 3g since the HK pre outs died and i need to start breaking everything down to move in a couple monthsHeadphones:Source: tidalDAC: schiit modius epre: schiit sysAmp: AQ dragonfly black/ schiit magni2 Cans: Velodyne V-True, Grado SR225i, sennheiser x drop gaming headsetPC:DAC: schiit modius e(over spdif)pre: schiit sysspeakers: prenous eris 5 xtSub: Earthquake Sound MiniMe-P63most of my comments are passing on of info, im a noob, im just trying to help how i can, if im wrong or out of place to comment, dont hesitate to let me know
I use Sound Forge but only to record. It's pop filter is not good and distorts the music. I do all cleanup in another wav editor then to flac.What do you guys use for ripping vinyl to FLAC?---
Polk Studio Monitor 4.6 Series 2's, Polk RT1000p's, Polk LSi25's, Boston Acoustic VR-975's
Crown D-75, Crown CE1000, Crown CE2000
