Putting together a system
I going to put together a system piece by piece. I was told to get the best center channel you can afford as most sound comes from the center speaker. This is what I was thinking about getting and was just wandering in this system goes together well. Let me know what you think, like if I should change a piece out.
FLOOR STANDING - RTIA7
CENTER - CSIA6
SURROUND - F/XIA6
SUB - DSWPRO660WI
I have a Denon AVR 2307CI
CENTER - CSIA6
SURROUND - F/XIA6
SUB - DSWPRO660WI
Speaker choice is fine. But that reciever dosen't have enough juice to power them.
What should I do? Get a different Receiver or a Amp?
If your happy with the reciever. It HAS preouts for an amp. Get a three or five channel amp. Those speakers love and need power.
even if you dont care much for that avr, you can always upgrade it later, from what i've seen on here, you will want an amp with those regardless of your avr, so if you have the ability to use an amp, do it and make the most of what you have,2 Channel(work in progress):DAC: Schiit modi 2 uberAmp:Parasound 1200 MK IISub:RBH 1010-SEP Speakers: Monitor 5A peerlesscurrently running some krk rokit 3g since the HK pre outs died and i need to start breaking everything down to move in a couple monthsHeadphones:Source: tidalDAC: schiit modius epre: schiit sysAmp: AQ dragonfly black/ schiit magni2 Cans: Velodyne V-True, Grado SR225i, sennheiser x drop gaming headsetPC:DAC: schiit modius e(over spdif)pre: schiit sysspeakers: prenous eris 5 xtSub: Earthquake Sound MiniMe-P63most of my comments are passing on of info, im a noob, im just trying to help how i can, if im wrong or out of place to comment, dont hesitate to let me know
"WITH WILLING HEARTS AND SKILLFUL HANDS, THE DIFFICULT WE DO AT ONCE, THE IMPOSSIBLE TAKES A BIT LONGER, WITH COMPASSION FOR OTHERS. WE BUILD - WE FIGHT FOR PEACE WITH FREEDOM"Seabee Memorial, Arlington, VA -
Another option is to go with the RTIA5 instead or a7. Your reveiver will have plenty of power to drive those and you are going to be using the sub for lower frequencies anyway, so you don't really need the a7.Living Room 7.1 HT Rig:
M70 | CS2 | M60 | Atrium5 - Surr. | SUB - Emotiva ULTRA12 + Tara Labs sub cable | Pioneer Elite VSX-52 | Parasound HCAs 1000A | Sony BDP-S790 | Belkin PureAV PF60 | MIT Exp2 Wires
Bedroom 5.0 HT Rig (Music/Movies/Gaming) :
LSi9 | LsiC | Lsi/fx | Marantz SR7002 | NAD T955 | Sony BDP-S360 | Belkin PureAV PF30 | AQ Blue Racer II ICs & AQ Type 4 wires | PS3 -
While the 660 is a good sub, you might also look into other subs from makers such as epik, hsu, or svs.Pioneer SC-25 | Adcom GFA-555 | KEF q900 Front | KEF q600 Center | Polk Monitor 30 Rear | Polk CS2 Rear Surround | Polk DSWPRO 660wi sub
