Putting together a system
sports96
sports96 Posts: 2
edited January 2013 in Speakers
I going to put together a system piece by piece. I was told to get the best center channel you can afford as most sound comes from the center speaker. This is what I was thinking about getting and was just wandering in this system goes together well. Let me know what you think, like if I should change a piece out.
FLOOR STANDING - RTIA7
CENTER - CSIA6
SURROUND - F/XIA6
SUB - DSWPRO660WI
I have a Denon AVR 2307CI
  • chumlie
    chumlie Posts: 8,658
    edited January 2013
    Speaker choice is fine. But that reciever dosen't have enough juice to power them.
  • sports96
    sports96 Posts: 2
    edited January 2013
    What should I do? Get a different Receiver or a Amp?
  • chumlie
    edited January 2013
    If your happy with the reciever. It HAS preouts for an amp. Get a three or five channel amp. Those speakers love and need power.
  • seabeerob213
    seabeerob213 Posts: 1,843
    edited January 2013
    even if you dont care much for that avr, you can always upgrade it later, from what i've seen on here, you will want an amp with those regardless of your avr, so if you have the ability to use an amp, do it and make the most of what you have,
  • Lietuvis91
    Lietuvis91 Posts: 909
    edited January 2013
    Another option is to go with the RTIA5 instead or a7. Your reveiver will have plenty of power to drive those and you are going to be using the sub for lower frequencies anyway, so you don't really need the a7.
    Living Room 7.1 HT Rig:
    M70 | CS2 | M60 | Atrium5 - Surr. | SUB - Emotiva ULTRA12 + Tara Labs sub cable | Pioneer Elite VSX-52 | Parasound HCAs 1000A | Sony BDP-S790 | Belkin PureAV PF60 | MIT Exp2 Wires
    Bedroom 5.0 HT Rig (Music/Movies/Gaming) :
    LSi9 | LsiC | Lsi/fx | Marantz SR7002 | NAD T955 | Sony BDP-S360 | Belkin PureAV PF30 | AQ Blue Racer II ICs & AQ Type 4 wires | PS3
  • bansheesho
    bansheesho Posts: 227
    edited January 2013
    While the 660 is a good sub, you might also look into other subs from makers such as epik, hsu, or svs.
    Pioneer SC-25 | Adcom GFA-555 | KEF q900 Front | KEF q600 Center | Polk Monitor 30 Rear | Polk CS2 Rear Surround | Polk DSWPRO 660wi sub
