The sounds of slab
Early B.
Early B. Posts: 7,900
edited May 2004 in Speakers
Anyone put slabs under their front speakers to enhance the bass? Is this a tweak worth pursuing?
"God grooves with tubes."
  • HBombToo
    HBombToo Posts: 5,256
    edited May 2004
    My theater and listening room is on a cement slab so no I won't. Wood should IMHO
    HBomb
    ***WAREMTAE***
  • gregure
    gregure Posts: 871
    edited May 2004
    I've always found bass to be tremendously enhanced when the speaker was directly laid on a non-cement flooring, like carpet over wood or hard wood floors. Bookshelf speakers on wooden bookshelves or cabinets that are sitting on the floor really seems to enhance the bass resonance across a whole room. The Rti's however, still produce a great bass resonance in my room, despite being lifted from the floor on the plastic feet. In my case, it's not really worth fitting wood slabs underneath, as I'm perfectly happy with my bass output as is.
    Current System:
    CSi5-Center (for sale**)
    FXi3-surrounds (for sale**)
    Martin Logan Depth-Sub
    B&K AVR 507
    Pimare CD21-CD Player
    Denon 1815-DVD Player
    Panamax M5500-EX-Line Conditioner
  • HBombToo
    edited May 2004
    your story would change if you had an SVS:D
    h
    ***WAREMTAE***
