The sounds of slab
Anyone put slabs under their front speakers to enhance the bass? Is this a tweak worth pursuing?
HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes."
Post edited by Early B. on
My theater and listening room is on a cement slab so no I won't. Wood should IMHO
HBomb***WAREMTAE*** -
I've always found bass to be tremendously enhanced when the speaker was directly laid on a non-cement flooring, like carpet over wood or hard wood floors. Bookshelf speakers on wooden bookshelves or cabinets that are sitting on the floor really seems to enhance the bass resonance across a whole room. The Rti's however, still produce a great bass resonance in my room, despite being lifted from the floor on the plastic feet. In my case, it's not really worth fitting wood slabs underneath, as I'm perfectly happy with my bass output as is.Current System:
CSi5-Center (for sale**)
FXi3-surrounds (for sale**)
Martin Logan Depth-Sub
B&K AVR 507
Pimare CD21-CD Player
Denon 1815-DVD Player
Panamax M5500-EX-Line Conditioner -
your story would change if you had an SVS:D
h***WAREMTAE***
