Music After Shutdown
deronb1
deronb1 Posts: 5,021
edited January 2013 in Electronics
After reading an old review on the Adcom GFA-555 from Julian Hirsch, he mentioned that the amp will continue to play for 10-15 seconds after the power is shut off. I thought that was weird, so I tried it, and it did!
Do most amps do this? I figure power is stored in the capacitors, but it seems odd that it continues to play so long.
Post edited by deronb1 on
  • Tbone289
    Tbone289 Posts: 661
    edited December 2012
    I wouldn't say "most", but some do. Tube amps do. Most SS amps I've used have a relay that cuts the audio path immediately when the amp is switched off.
    It's best to turn off components in order from final amp stage to source, and reverse on power-up. During both procedures, it's best to have any gain controls at minimum.
    2.1: PC>Schiit Gungnir MB>Schiit Freya Noval>NAD C-270>Ascend Acoustics Sierra-1, HSU STF-2 5.1: HDMI Bitstream>Denon AVR-1910>polkaudio RTE55, CS350-LS, RT3, HSU STF-2, Visio M55-F0
  • scottyboy76
    scottyboy76 Posts: 2,905
    mine plays at least that long after shutdown, and then the right channel farts, thats the closest description of the sound, have seen here where heiney9 and others way more educated on adcom than me say its completely normal.
    humpty dumpty was pushed
  • On3s&Z3r0s
    On3s&Z3r0s Posts: 1,013
    Tbone289 wrote: »
    It made me smile to see this. It seems like such a simple process all wrapped up in one neat little sentence, and yet I'm the only guy in the house that seems to get the order right. Every time I hear a "Pop" and an "Oops!" I wish I hadn't taken out those polyswitches for just a second. :frown::smile:
  • leftwinger57
    leftwinger57 Posts: 2,917
    edited January 2013
    mine doesn't continue to play but there is that deflating balloon sound when it's relieving the last juice it has .That noise is again not quite farts but deflating balloons,certainly no music.
  • deronb1
    edited January 2013
    Are you sure? Try playing something for about 5 min and then turn off the amp only. Leave everything else playing. I betcha it will continue to play. :cheesygrin:
  • Monster Jam
    Monster Jam Posts: 919
    edited January 2013
    My GFA-555 does the same thing after powering down. I make sure that the music plays through before I disconnect the input from my PC. Last time I blew something in my Adcom when I touched the input to ground.
    Do you hear that buzzing noise? :confused:
    treitz3 Posts: 19,988
    edited January 2013
    My Musical Fidelity AC3r will continue to play for approximately that long and I have had a handful of amplifiers over the years that have done the same thing.
  • Syndil
    Syndil Posts: 1,582
    edited January 2013
    My Adcom GFA-6000 and GFA-545II will also do the same, if I allow them to.
  • nguyendot
    nguyendot Posts: 3,594
    edited January 2013
    It's normal for the 555. No power on relays in the path. The lights in front fade out too.
    Main Surround -
