Polarized Cap
zingo
I'm replacing the C5 470uF caps in a Hafler DH200 with new electrolytics, but I just realized that the originals are bipolar and my new ones are standard polarized. Which way should I install the polarized caps in the circuit, or will it not work at all?
Thanks for the help!
Post edited by zingo on
What was the answer ?Speakers: SDA-1C (most all the goodies)
Not possible.
Sure it is.For signal coupling the signal input should be applied to the positive lead.On supply rails the positive lead should be connected to the 'most positive' side of the circuit. -
Thanks for the intellegent correction; I always enjoy a good lesson.
It looks like I need to put the original caps back in, power up the amp and measure each side of the cap, then install the new caps appropriately. -
I would never replace a non-polarized cap with a polarized one. Worst case, if you really want to do it, take two polarized caps, solder them together "-" to "-", this way you'll have a non-polarized cap. Just make sure the value is right, as two caps in series is like a two resistors in parallel. Is it worth the effort? Not to me.
Btw, manufacturers will always put polraized cap wherever possible, as they are generally smaller and cheaper than non-polarized ones.
Of course, there are applications like filtering to ground, where you can put a polarized cap instead, as long as you put it the right way. I'd rather order the right part anyway.Panasonic PT-AE4000U projector for movies
Denon AVR-X3600H pre/pro
B&W CDM1-SE fronts
B&W CDM-CNT center
B&W CDM1 rears on MoPADs
DUAL NHT SubTwo subwoofers
Oppo BDP-93 Blu-Ray player
Belkin PF60 Power Center
Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room -
I completely agree with you. I knew the two cap trick, but it was much better to say "no", than the alternative...
Ugh, those look baaaad. But on a bright side, there is nothing like opening an amp and finding a problem just by looking at the board.Panasonic PT-AE4000U projector for movies
B&W CDM1-SE fronts
B&W CDM-CNT center
Thanks guys, learn something new everyday.Speakers: SDA-1C (most all the goodies)
I agree that finding a ruptured cap or burnt resistor is exciting to find when you're trouble-shooting a piece of electronics!
Not sure that 'exciting' would be the word I'd choose, but hey...it certainly can help speed the diagnosis!
C5 is in the feedback loop so you can try the polarized cap with it's negative lead in the R22 side of circuit until you find suitable NP's.The cap will not be seeing large reverse voltages so it will not atomize itself.The purpose of this cap is to prevent amplifying any DC that may appear at the output.
