"Tube Like"!
Unknown
edited December 2012 in The Clubhouse
How many times have you heard that?
  • Systems
    Systems Posts: 14,873
    I gotta say, I got a silly cheap amp that is "described" as "Tube Like"
    Just wondering if it is?
    I hate to mention it because of the flak I may receive!
    I will give you a hint however, HK (old), and pretty sweet.
    Has been described as "tube like" on several occasions.
    You think its possible?
    SS........Tubelike?
    Testing
    Testing
    Testing
  • decal
    decal Posts: 3,205
    I have heard some cheap tube amps that sounded like cheap SS amps. Hope that helps !!!!!
    tonyb Posts: 33,072
    There's different degrees of that tube like sound. Just like there is for SS. Some amps that portray a more musical warm sound are considered tube like, but not really all the way there. Once you get your ears on good tubed gear, it's pretty hard to accept anything less after that.
  • deronb1
    deronb1 Posts: 5,021
    My wife is still blowing me crap for buying a "tube buffer". I told her it's not to replace her. :sad:
  • decal
    decal Posts: 3,205
    deronb1 wrote: »
    Touche' !!!!!!!!
  • Dawgfish
    Dawgfish Posts: 2,554
    I had a B&K ST-202+ that was somewhat tube like in it's presentation. Like Tony was saying not quite all the way there, but leaning more towards tube sound than most solid state. That was a great amp.
  • polkfarmboy
    polkfarmboy Posts: 5,703
    I thought tube like is just used describe it as not being so sterile as most ss equipment does have a sterile clinical sound
