Can Yamaha CR 2020 receiver run SDA 2 speakers?
I am in the process of getting a great pair of Polk SA 2 speakers and just thought of something:
whether my Yamaha CR 2020 receiver will be able to run the SDA 2's?
I believe the SDA 2s are 4 OHM speakers. Is that correct?
Will my Yamaha CR 2020 have any problems running the SDA 2's?
Thanks,
Peter
Thanks,
Peter
According to the specs i found it is not rated to 4olm therefor would not recomend for a load like that.Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable
