Can Yamaha CR 2020 receiver run SDA 2 speakers?
pglbook
pglbook Posts: 2,267
edited December 2012 in Speakers
I am in the process of getting a great pair of Polk SA 2 speakers and just thought of something:
whether my Yamaha CR 2020 receiver will be able to run the SDA 2's?
I believe the SDA 2s are 4 OHM speakers. Is that correct?
Will my Yamaha CR 2020 have any problems running the SDA 2's?
Thanks,
Peter
  • soundfreak1
    soundfreak1 Posts: 3,414
    According to the specs i found it is not rated to 4olm therefor would not recomend for a load like that.
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
