Warm sounding solid state integrated/seperates under $1500
c_corie
Looking for ideas for CM8s I want something with a decent bottom end and power and maybe a softer top end. Will be using a Hegel HD2 dac and open to amp/cable combos. I think I've ruled out tube amps-they seem to sound best at a decent volume-most of my listening will be lower/apartment levels.
Post edited by c_corie on
Belles, B&K, Butler, McCormack for starters. Pass labs too.HT SYSTEM-
lsi 9's -
None of these are available locally. I'd like to buy online-with an easy exchange/return policy. I'm located in CT. All anyone seems to carry here is marantz, Rotel, Anthem, Hegel, Classe, NAD, and maybe a few ultra high end things.
Of the above, I've heard NAD, Anthem, and Classe. I think they'd all be classified as warmish for SS amps. Rotel, not as much. And Hegel, I just have not heard.
Some of the Marantz integrateds might be OK too. You need to get your ears on those and decide for yourself.
Good luck. I think you "do" have enough to choose from there!
Carver TFM seriesSpeakers: SDA-1C (most all the goodies)
The Mccormack amps are very good. See if you can get a used dna-1.
First, how is your room treatment situation? Always start there, it's the easiest way to improve/change your sound. If you can audition SimAudio, even a their previous base model the i.5 has a touch of SS warmth. The Rega Brio is another choice, though I'm a bit surprised the Hegel integrated doesn't spark your interest, even if it is a bit out of your price range. I'd probably be tempted to save a bit longer and go that route.Review Site_ (((AudioPursuit)))
Former Staff Member TONEAudio
2 Ch. System
Cable/Wires: Cardas, AudioArt, Shunyata Venom 3 -
Since you are unsure i recomend sepporate amp amd pre instead of intergrated. This will give you more flexability too work with as far as upgrading and getting you the sound you like. Would sugguest looking at parasound as well (very warm sounding) and they fit the description of sound you mentioned.Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable -
Let me say the speakers have not arrived yet, and I only tested the Hegel dac through his CM9/tube/sub setup and it was nice but almost a little too relaxed and that was through tube so I want something more clean/bright then tube but still warm for solid state. Also my listening area is a big open living room in new apt...can I post a pic here some now? I just moved I so it's empty and waiting for a stereo
I would suggest you save the money and stick with an integrated amp. The quality of them has jumped dramatically in the past 7 years. Plus with the money you save you can buy a second integrated of a different amplification style. I have three, SS, Tube, and Class D, and over the course of a year I rotate thru all three.Review Site_ (((AudioPursuit)))
2 Ch. System
I personally find ICEpower to have a warmer sound with great bass slam. I have a pair of 525wpc monoblocks for sale in the CP Classifieds that are ICEpower w/in your price range. If you don't need that much power you could go with a Wyred 4 Sound amp @ 125wpc for $1k, or go with one of their integrateds.
Another warm sounding amp brand would be Parasound. I owned and really liked their A23 stereo amp and A52 surround amp. Where in CT are you located? I purchased my Parasounds from Connect-Tech in Longmeadow, just over the MA border. -
I have one of these...it made a huge impact in my listening quality.
http://www.avahifi.com/index.php?option=com_content&view=article&id=155&Itemid=221
From the website. "Our best sounding solid-state amplifier and likely the most musical and transparent at any price."
Gaara:
You're the first person I've ever met to describe ICE power as warm, and if that is what you hear more power to you. But, the growing trend with ICE amps is the inclusion of a tube buffer to warm the sound speaks to general opinion that ICE amps are more likely to sound dry or technical.Review Site_ (((AudioPursuit)))
2 Ch. System
markmarc,
I wouldn't say it is as warm as a class A amp, but yeah to me they err on the side of warm. Maybe its in the definition, most of the icepower amps I have heard have detail in the highs but they are never harsh, which I always attributed to their slow roll-off in the treble, hence my opinion on them being warm.
Looking at your sig I had a PS Audio Trio a few years back, and it was one of the ICEpower amps I owned which I would NOT describe as warm sounding. -
Garda:
Ive been lucky enough to compare the stock Trio against my modified one, and you are correct that the stock model is not warm in the least. The modded improves the situation, but the two different Wyred4Sound models I've spent time with as well as the Wadia and the Virtue Audio (with tube buffer off) equally as technical sounding. I do hope ICE continues to improve or that tube buffers are adopted universally.Review Site_ (((AudioPursuit)))
2 Ch. System
Carver TFM series
A good inexpensive route, my 35 is warm as toast, my 55 isn't quite as warm but, still warmish nonetheless. I have a MF tube buffer in the mix too, tube sound without all the tube work, IMO.
Parasound 1500 matches that description. Definitely warmer than a NAD.Living Room 7.1 HT Rig:
M70 | CS2 | M60 | Atrium5 - Surr. | SUB - Emotiva ULTRA12 + Tara Labs sub cable | Pioneer Elite VSX-52 | Parasound HCAs 1000A | Sony BDP-S790 | Belkin PureAV PF60 | MIT Exp2 Wires
Bedroom 5.0 HT Rig (Music/Movies/Gaming) :
LSi9 | LsiC | Lsi/fx | Marantz SR7002 | NAD T955 | Sony BDP-S360 | Belkin PureAV PF30 | AQ Blue Racer II ICs & AQ Type 4 wires | PS3 -
My 2 cents is the Peachtree intigrated amps, these fit well in your budget and can be used as a pre amp if you decide to move to a bigger outboard still.
Parasound seems neat-where should I buy and how much should they cost-what models are good what should I avoid? Also does their higher end series come in black?
their classic series comes in black, they do sound good. not to dry and not too warm.
What about tube amps? Or maybe something lie the Red Wine Sig 15? These speakers will be used most likely at quite low volumes
I have a tube amp in my 2-channel system (see sig), and I find that the tonal character is less volume-dependent than any SS amp I've owned. I'm not sure if that's the case for lower-powered tube amps though--mine is ~40 watts per channel. I use mine at mostly low volume in a nearfield setup. To me it sounds quite good at low volume levels.2.1: PC>Schiit Gungnir MB>Schiit Freya Noval>NAD C-270>Ascend Acoustics Sierra-1, HSU STF-2 5.1: HDMI Bitstream>Denon AVR-1910>polkaudio RTE55, CS350-LS, RT3, HSU STF-2, Visio M55-F0
I may not be far from you. Maybe we should get together sometime and listen to my Belles 350a amplifier and Anthem pre2L tube pre- amp combination along with your speakers. Just an idea!!!!!!!!!!!!!!
+2 on Belles (One and XLM)
B&W speakers will sound super-warm with Rotel amps. Linn and other UK manufacturers will also be very warm sounding.Panasonic PT-AE4000U projector for movies
Denon AVR-X3600H pre/pro
B&W CDM1-SE fronts
B&W CDM-CNT center
B&W CDM1 rears on MoPADs
DUAL NHT SubTwo subwoofers
Oppo BDP-93 Blu-Ray player
Belkin PF60 Power Center
Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room -
www.audioadvisor.com for the Parasound and the Halo series is coming in black.Parasound seems neat-where should I buy and how much should they cost-what models are good what should I avoid? Also does their higher end series come in black? -
I'll put a plug in for my NAD c375BEE integrated; lots of power and neutral. I tend to see more change in warmth based on which DAC I have attached. Using MIT AVT2 cables / ICs, but have used Signal Silver / Ultras as well.
Otherwise..+1 for Parasound. Typically warm sound.Dali Optikon 1Mk2
NAD D3020 V2
Schiit Bifrost 2/64
..the rest are headphone setups. -
Warm and cheap think vintage. I have a 70's Yamaha with a wood case that can operate in just class A up to the first 10 wts then changes to AB. You can pick these heavy boys up for $200 ish all day long and they can even throw in a little heat into your room for those long winter nights.
Main Family Room: Sony 46 LCD, Sony Blue Ray, Sony DVD/VCR combo,Onkyo TXNR 708, Parasound 5250,
Living Room: Belkin PF60, Parasound HCA2200, MIT ProlineEXP balanced IC's,Emotiva XDA-1 DAC/Pre,Emotiva ERC2 transport,MIT AVT2, Polk LSI 9's. -
well vintage opens up a whole new can.........the old yamaha B series threshold class A with a refurb from Soderberg in calif.......forte.......
Is something like a Yamaha A-S300/500 worth it? Reasonable prices and I tend to like their build quality. Are they warm/cold/dry?
