Warm sounding solid state integrated/seperates under $1500
c_corie
c_corie Posts: 138
edited January 2013 in 2 Channel Audio
Looking for ideas for CM8s I want something with a decent bottom end and power and maybe a softer top end. Will be using a Hegel HD2 dac and open to amp/cable combos. I think I've ruled out tube amps-they seem to sound best at a decent volume-most of my listening will be lower/apartment levels.
Post edited by c_corie on
    tonyb Posts: 33,024
    edited December 2012
    Belles, B&K, Butler, McCormack for starters. Pass labs too.
  • c_corie
    c_corie Posts: 138
    None of these are available locally. I'd like to buy online-with an easy exchange/return policy. I'm located in CT. All anyone seems to carry here is marantz, Rotel, Anthem, Hegel, Classe, NAD, and maybe a few ultra high end things.
    Of the above, I've heard NAD, Anthem, and Classe. I think they'd all be classified as warmish for SS amps. Rotel, not as much. And Hegel, I just have not heard.
    Some of the Marantz integrateds might be OK too. You need to get your ears on those and decide for yourself.
    Good luck. I think you "do" have enough to choose from there!
    cnh
  • thsmith
    thsmith Posts: 6,082
    Carver TFM series
  • usp1
    usp1 Posts: 207
    The Mccormack amps are very good. See if you can get a used dna-1.
  • markmarc
    markmarc Posts: 2,309
    First, how is your room treatment situation? Always start there, it's the easiest way to improve/change your sound. If you can audition SimAudio, even a their previous base model the i.5 has a touch of SS warmth. The Rega Brio is another choice, though I'm a bit surprised the Hegel integrated doesn't spark your interest, even if it is a bit out of your price range. I'd probably be tempted to save a bit longer and go that route.
    Former Staff Member TONEAudio
    2 Ch. System
  • soundfreak1
    soundfreak1 Posts: 3,414
    Since you are unsure i recomend sepporate amp amd pre instead of intergrated. This will give you more flexability too work with as far as upgrading and getting you the sound you like. Would sugguest looking at parasound as well (very warm sounding) and they fit the description of sound you mentioned.
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
  • c_corie
    c_corie Posts: 138
    Let me say the speakers have not arrived yet, and I only tested the Hegel dac through his CM9/tube/sub setup and it was nice but almost a little too relaxed and that was through tube so I want something more clean/bright then tube but still warm for solid state. Also my listening area is a big open living room in new apt...can I post a pic here some now? I just moved I so it's empty and waiting for a stereo
  • markmarc
    I would suggest you save the money and stick with an integrated amp. The quality of them has jumped dramatically in the past 7 years. Plus with the money you save you can buy a second integrated of a different amplification style. I have three, SS, Tube, and Class D, and over the course of a year I rotate thru all three.
    2 Ch. System
  • Gaara
    Gaara Posts: 2,415
    I personally find ICEpower to have a warmer sound with great bass slam. I have a pair of 525wpc monoblocks for sale in the CP Classifieds that are ICEpower w/in your price range. If you don't need that much power you could go with a Wyred 4 Sound amp @ 125wpc for $1k, or go with one of their integrateds.
    Another warm sounding amp brand would be Parasound. I owned and really liked their A23 stereo amp and A52 surround amp. Where in CT are you located? I purchased my Parasounds from Connect-Tech in Longmeadow, just over the MA border.
  • dkr919
    dkr919 Posts: 379
    I have one of these...it made a huge impact in my listening quality.
    http://www.avahifi.com/index.php?option=com_content&view=article&id=155&Itemid=221
    From the website. "Our best sounding solid-state amplifier and likely the most musical and transparent at any price."
  • markmarc
    Gaara:
    You're the first person I've ever met to describe ICE power as warm, and if that is what you hear more power to you. But, the growing trend with ICE amps is the inclusion of a tube buffer to warm the sound speaks to general opinion that ICE amps are more likely to sound dry or technical.
    2 Ch. System
  • Gaara
    Gaara Posts: 2,415
    markmarc,
    I wouldn't say it is as warm as a class A amp, but yeah to me they err on the side of warm. Maybe its in the definition, most of the icepower amps I have heard have detail in the highs but they are never harsh, which I always attributed to their slow roll-off in the treble, hence my opinion on them being warm.
    Looking at your sig I had a PS Audio Trio a few years back, and it was one of the ICEpower amps I owned which I would NOT describe as warm sounding.
  • markmarc
    Garda:
    Ive been lucky enough to compare the stock Trio against my modified one, and you are correct that the stock model is not warm in the least. The modded improves the situation, but the two different Wyred4Sound models I've spent time with as well as the Wadia and the Virtue Audio (with tube buffer off) equally as technical sounding. I do hope ICE continues to improve or that tube buffers are adopted universally.
    2 Ch. System
  • gdb
    gdb Posts: 6,012
    Pass ? Warm ? Did not think that possible.
  • gdb
    gdb Posts: 6,012
    thsmith wrote: »
    Carver TFM series
    A good inexpensive route, my 35 is warm as toast, my 55 isn't quite as warm but, still warmish nonetheless. I have a MF tube buffer in the mix too, tube sound without all the tube work, IMO. :wink:
  • Lietuvis91
    Lietuvis91 Posts: 908
    Parasound 1500 matches that description. Definitely warmer than a NAD.
    Living Room 7.1 HT Rig:
    M70 | CS2 | M60 | Atrium5 - Surr. | SUB - Emotiva ULTRA12 + Tara Labs sub cable | Pioneer Elite VSX-52 | Parasound HCAs 1000A | Sony BDP-S790 | Belkin PureAV PF60 | MIT Exp2 Wires
    Bedroom 5.0 HT Rig (Music/Movies/Gaming) :
    LSi9 | LsiC | Lsi/fx | Marantz SR7002 | NAD T955 | Sony BDP-S360 | Belkin PureAV PF30 | AQ Blue Racer II ICs & AQ Type 4 wires | PS3
  • logo896
    logo896 Posts: 322
    My 2 cents is the Peachtree intigrated amps, these fit well in your budget and can be used as a pre amp if you decide to move to a bigger outboard still.
  • c_corie
    c_corie Posts: 138
    edited January 2013
    Parasound seems neat-where should I buy and how much should they cost-what models are good what should I avoid? Also does their higher end series come in black?
  • wkjeffers
    wkjeffers Posts: 139
    edited January 2013
    their classic series comes in black, they do sound good. not to dry and not too warm.
  • c_corie
    c_corie Posts: 138
    edited January 2013
    What about tube amps? Or maybe something lie the Red Wine Sig 15? These speakers will be used most likely at quite low volumes
  • Tbone289
    Tbone289 Posts: 661
    edited January 2013
    I have a tube amp in my 2-channel system (see sig), and I find that the tonal character is less volume-dependent than any SS amp I've owned. I'm not sure if that's the case for lower-powered tube amps though--mine is ~40 watts per channel. I use mine at mostly low volume in a nearfield setup. To me it sounds quite good at low volume levels.
    2.1: PC>Schiit Gungnir MB>Schiit Freya Noval>NAD C-270>Ascend Acoustics Sierra-1, HSU STF-2 5.1: HDMI Bitstream>Denon AVR-1910>polkaudio RTE55, CS350-LS, RT3, HSU STF-2, Visio M55-F0
  • NJPOLKER
    NJPOLKER Posts: 3,474
    edited January 2013
    I may not be far from you. Maybe we should get together sometime and listen to my Belles 350a amplifier and Anthem pre2L tube pre- amp combination along with your speakers. Just an idea!!!!!!!!!!!!!!
  • ErasmusBDragon
    ErasmusBDragon Posts: 113
    edited January 2013
    +2 on Belles (One and XLM)
  • ViperZ
    ViperZ Posts: 2,046
    edited January 2013
    B&W speakers will sound super-warm with Rotel amps. Linn and other UK manufacturers will also be very warm sounding.
    Panasonic PT-AE4000U projector for movies
    Denon AVR-X3600H pre/pro
    B&W CDM1-SE fronts
    B&W CDM-CNT center
    B&W CDM1 rears on MoPADs
    DUAL NHT SubTwo subwoofers
    Oppo BDP-93 Blu-Ray player
    Belkin PF60 Power Center
    Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
  • chumlie
    chumlie Posts: 8,658
    edited January 2013
    c_corie wrote: »
    www.audioadvisor.com for the Parasound and the Halo series is coming in black.
  • PrazVT
    PrazVT Posts: 1,606
    edited January 2013
    I'll put a plug in for my NAD c375BEE integrated; lots of power and neutral. I tend to see more change in warmth based on which DAC I have attached. Using MIT AVT2 cables / ICs, but have used Signal Silver / Ultras as well.
    Otherwise..+1 for Parasound. Typically warm sound.
    ALL BOXED UP for a while until I save up for a new place :(
    Home Theater:
    KEF Q900s / MIT Shotgun S3 / MIT CVT2 ICs | KEF Q600C | Polk FXi5 | BJC Wire | Signal / AQ ICs | Shunyata / Pangea PCs | Pioneer Elite SC 57 | Parasound NC2100 Pre | NAD M25 | Marantz SA8001 | Schiit Gungnir DAC | SB Touch
    2 Channel:
    Polk LSi9 (xo mods), Polk DSW MicroPro 2000 sub | NAD c375BEE | W4S DAC1 | SB Touch | Marantz SA-8001 | MIT AVt 2 | Kimber Hero / AQ / Signal ICs | Shunyata / Signal PCs
  • michael1947
    michael1947 Posts: 775
    edited January 2013
    Warm and cheap think vintage. I have a 70's Yamaha with a wood case that can operate in just class A up to the first 10 wts then changes to AB. You can pick these heavy boys up for $200 ish all day long and they can even throw in a little heat into your room for those long winter nights.:lol:
    Main Family Room: Sony 46 LCD, Sony Blue Ray, Sony DVD/VCR combo,Onkyo TXNR 708, Parasound 5250,
    Living Room: Belkin PF60, Parasound HCA2200, MIT ProlineEXP balanced IC's,Emotiva XDA-1 DAC/Pre,Emotiva ERC2 transport,MIT AVT2, Polk LSI 9's.
  • wkjeffers
    edited January 2013
    well vintage opens up a whole new can.........the old yamaha B series threshold class A with a refurb from Soderberg in calif.......forte.......
  • c_corie
    c_corie Posts: 138
    edited January 2013
    Is something like a Yamaha A-S300/500 worth it? Reasonable prices and I tend to like their build quality. Are they warm/cold/dry?
