Two subs and Lsi-7's
Bigbang
Bigbang Posts: 233
I have an HT setup with Lsi-7's for right and left and an Lsi-C for center. 5jr's for rear surround. The Lsi-7's don't have enough bass for HT so I purchased two Yamaha YST-125's. my question is how should I connect them to my HK-3600? Should I use the single sub output and split it or should I run it through the left and right output before the signal hits the Lsi-7 speakers?
I like to listen, tinker, listen and repeat.
Post edited by Bigbang on
    txcoastal1 Posts: 13,518
    edited December 2012
  • Bigbang
    Bigbang Posts: 233
    Nice y splitter. Any suggestions on an RCA to RCA cable? Should I stick with audioquest?
  • classic carl
    classic carl Posts: 662
    Bigbang wrote: »
    You could, but it's not imperative. Whatever you are using for the rest of your system would be OK. I use AQ for my HT and main 2 channel systems.
    Main System 2.2:
    Proton AA-1150 ~ Yamaha C-4 ~ Furman Elite-15 DMi ~ Sennheiser HD600 ~ Monitor Audio Silver RS8
    (2x) Martin Logan Dynamo ~ Marantz CD5003 ~ Squeezebox Classic ~ Music Hall dac25.2 ~ Sansui D-X111R
    Dual 1229/Acutex M312 III STR ~ Music Hall mmf-5.1/Goldring 1012GX ~ Music Hall Cruise Control 2.0
    Home Theater 5.2:
    Yamaha RX-V800 ~ Furman Elite-15 DMi ~ Polk Audio RT55i ~ RT35i ~ CS400i ~ (2x) PSW450
    Winter Residence 2.1 (laptop system):
    Yamaha RX-485 ~ Squeezebox Classic ~ Topping D30 ~ EPI M90 ~ Dayton Audio SUB-1200
  • Bigbang
    Bigbang Posts: 233
    Thanks guys. I always get good advice here!
