Recommend Receiver for my setup
dirtydenim86
dirtydenim86 Posts: 95
edited January 2013 in Electronics
Hey Guys,
This will be my first home theater setup I am picking up pieces as I go so far I have:
2 x RTI10 Polk Audio Front Tower Speakers
2 x RTI4 Pol Audio Bookself (for rear)
1 x CSi5 Center Channel RTI Series Speaker
I am loooking for a receiver to go with this setup preferably in the $250-$300 range.
http://www.futureshop.ca/en-CA/product/pioneer-pioneer-7-1-channel-network-receiver-vsx-1022-k-vsx-1022-k/10195884.aspx?path=d1e9c9e7d0e116de6fb28ab1cc1ea13fen02
I have been looking at the Pioneer 1022k right now but haven't pulled the trigger yet looking for some input.
Thanks!
Onkyo TX-NR809
RTI4 Polk Audio Bookself
PSW505 12" Subwoofer
Post edited by dirtydenim86 on
  • specd_out
    specd_out Posts: 505
    edited December 2012
    Those RTi10s you have need a fair amount of power to really make them sing. The AVR you chose is solid but not quite powerful enough to push those speakers.
    I would recommend either looking for a used but more powerful amp. Maybe something in the Elite line. If you go this route get something with preouts. This way you can just add a power amp to the AVR when you get more funds and not have to buy a new avr for the preouts plus purchase a power amp. (I learned from my mistakes)
    Or get a nice sub (which you need anyway) set the crossover for 80hz. It will allow the avr to use all its power for the mids and the highs, and the subwoofer and its amp will handle the lows.
    If you listen to 2channel you can go into mcacc and set the subwoofer to "plus". This will allow the subwoofer to play in 2channel.
    HT Rig Samsung 64F8500 |Pioneer Elite BDP-52FD|Pioneer Elite VSX-32| Two Carver TFM-15cb Bridged for mains|Polk Audio RTiA5 Cherry|Polk Audio CsiA6 Cherry|Polk Audio T-15 Heights|Polk Audio FXia6 Surround|DIY 8cuft Dayton Ultimax 15" powered with a Crown XLS1000
    2Channel Rig Polk Audio LSi9 Cherry| Carver C-1BillD Mod|Carver M1.0t MkII Opt2|Pro-ject RM 1.3|SpeedBox S|AQ King Cobras|AQ Rocket88|
    ISF Level 2 Certified Calibrator
  • specd_out
    anonymouse wrote: »
    The price of this keeps fluctuating a bit, but is currently around $480. http://www.amazon.com/gp/product/B00505F01E/ref=ox_sc_act_title_1?t=slicinc-20&tag=slicinc-20&ie=UTF8&smid=ATVPDKIKX0DER
    You will need quite a receiver to power those RTi10's and CSi5. Would suggest you open up your budget a bit more to get more out of them.
    The problem with that 1022K is its not got enough power, and it does not have preamp outputs either, so you are kind of at a dead end in terms of extending its life with a separate amp down the road.
    Another alternative is to buy an older used receiver which can be had for real cheap, and use an HDMI switch to do your video switching. The HK 247 or 347 series would do great.
    same thing I said just a few seconds earlier. lol
  • Willow
    Willow Posts: 11,231
    do you need hdmi pass through? if not I say check you local kijiji or used(city) adds and do like mentioned above. just buy one that has preouts so you can add an ext amp later on down the line.
  • dirtydenim86
    specd_out wrote: »
    I am looking at getting this sub...
    http://www.newegg.com/Product/Product.aspx?Item=N82E16882290130
    I have the other items I listed I am just in the market for a receiver and a sub I know I probably did it backwards but just couldn't find a deal on a receiver worth pulling the trigger on got a decent deal on the speakers.
    I am new to the home theater scene and this will be my first setup I am not very familiar with what specs to look at when looking for a receiver to power my system what are some of the essientials when looking for a good receiver to power my front and rear speakers along with my center?
    Onkyo TX-NR809
  • dirtydenim86
    specd_out wrote: »
    If I were to go ahead and package the psw550 sub with the pioneer 1022k would that help?
    Onkyo TX-NR809
    tonyb Posts: 33,072
    You want to look for a receiver with preouts, which that one I don't think has. Why ? Because should you ever decide to move up the speaker chain, you will most likely need to add an amplifier which you cannot do without preouts.
  • B Run
    B Run Posts: 1,888
    Honestly that 1022 will leave you wanting more. I ran Rti8's (easier to drive), off an 1120 (more powerful) and still ended up adding an amp for more power. I'd either budget for a cheaper avr with pre outs or i'd spend a little more and do it right the first time. You've got a nice setup, you'll be glad you did.
  • dirtydenim86
    B Run wrote: »
    Are there any receiver suggestions in the $350 range that would allow me to get the best possible sound quality out of the RTI10s?
    Onkyo TX-NR809
  • cfrizz
    cfrizz Posts: 13,415
    Not any that have preouts for future power upgrades to get the full potential out of your speakers. Take your time, save a bit more money and get a better receiver that has preouts. If you want the best possible sound quality out of your speakers, you need to provide them with the power to do so, and a receiver in your price range will NOT get it done. As B Run said do it once and do it right the first time around.
    Welcome to Club Polk.
  • dirtydenim86
    cfrizz wrote: »
    How much power is recommended to make those rti10s sing?
    I noticed the Onkyo TX-NR809 has about 130 w for high mid lows?
    Pioneer has these specs:
    Power Output per Channel (20Hz-20kHz, 0.08%THD@8ohm): 80W
    Power Output per Channel (1kHz@8ohm): 110W
    Power Output per Channel (1kHz@6ohm): 140W
    For the Pioneer does that mean the highs are at 140W? Mids at 110? amd lows at 80W?
    Onkyo TX-NR809
    tonyb Posts: 33,072
    No, my good man, thats for the whole freq. response, or the whole speaker depending. Receiver power ratings are somewhat misleading. When you drive more speakers the power each gets goes down. Say 100 watts per channel, 2 channels driven is the spec, but at 5 channels driven it may drop to 80, and at 7 channels, may go as low as 30-40.
    350 is a tad on the low side unless you want to buy used.
  • dirtydenim86
    tonyb wrote: »
    No, my good man, thats for the whole freq. response, or the whole speaker depending. Receiver power ratings are somewhat misleading. When you drive more speakers the power each gets goes down. Say 100 watts per channel, 2 channels driven is the spec, but at 5 channels driven it may drop to 80, and at 7 channels, may go as low as 30-40. 350 is a tad on the low side unless you want to buy used.
    Would the Onkyo TX-NR809 for $480 be the best value on a receiver that would have enough power to support my setup?
    Onkyo TX-NR809
  • SugarmillMan
    SugarmillMan Posts: 175
    The Onkyo TX-NR809 will work just fine but will not produce the best possible sound you might hear. What everyone is telling you is to realize the very best from those speakers, you will need a fairly high powered receiver or better yet, an external amplifier.
    My advice would be to get the 809 for now and evaluate your need for an amplifier later. You could always add a reasonably priced Adcom, Rotel or Emotiva amp at a later.
    Fronts:B&W 804 Diamonds, Center: B&W HTM2 Diamond, Surrounds: PolkAudio LSi F/X (4)
    Subwoofer: HSU VTK3-MK3
    Electronics: Onkyo TX-NR 3010 receiver, Parasound Halo A31 amp, NAD T975 amp
  • chumlie
    chumlie Posts: 8,658
    Hard to beat at that price. Should serve your needs quite nicely.
  • dirtydenim86
    anonymouse wrote: »
    That is a $1,100 MSRP receiver. You would be hard pressed to do better for that receiver new. It will handle your setup initially will great results. Down the road, to get the best from your 10s, you may want to add an external amp, and the 809 has the preamp outs to allow you to do that. I have no idea what the duty on that to Canada would be, but if you are in the US, that receiver is a no brainer if you can spare the coin.
    Excellent I was going to get the Pioneer 1022k but as suggested I think I am going to wait on a receiver for now that way I won't rush and hate myself for doing it later.
    I am already going over to the states to pickup my csi5 and possibly a sub.
    If I purchased the Onkyo NR809 from that amazon link is it covered under the same warranty if I were to get it from Onkyo?
    Onkyo TX-NR809
  • dirtydenim86
    anonymouse wrote: »
    It is sold by directly by Amazon, and they list a 2 year limited warranty. Amazon is about as trustworthy a merchant as they come.
    I have ordered from them a few times seem to be fairly decent haven't had any issues with them either.
    Were there any other receivers that are recommended in the $480 price range that will pump my RTI10s?
    or is that as cheap a price I will find for a receiver of that sort?
    Also if I were to go with a cheaper AVR with that has the ability to add an amp later for power overall power how much do the amps go for?
    I am just debating whether to bite the bullet now and get a powerful receiver and sit back and relax or wait it out.
    Onkyo TX-NR809
    F1nut Posts: 51,776
    You might be able to pick up a Pioneer Elite SC-07 in that price range. It puts out its rated power with 5 channels driven and just a tad less with 7 channels driven. I doubt you'll ever feel the need to add an external amp to it.
  • dirtydenim86
    Looks like the Pioneer Elite SC-07 goes for about $750 on amazon.
    Appears that the Onkyo TX-NR809 might be the best bet as far as price and power.
    Onkyo TX-NR809
    F1nut Posts: 51,776
    Used SC-37's were selling for that money. Keep looking....places like eBay and Audiogon, do a Google search. Something will turn up in your price range.
  • seabeerob213
    seabeerob213 Posts: 1,843
    newegg has that sub for 190 for 3 more days, if you want it, nows the time
  • dirtydenim86
    Found it on amazon for the same price:
    http://www.amazon.com/Polk-Audio-12-Inch-Powered-Subwoofer/dp/B000092TT0
    decided to get it from there since newegg is a pain for Canadians.
    for a setup like this which speaker wire is recommended 12 gauge?
    Onkyo TX-NR809
  • RamZet
    RamZet Posts: 792
    +1
    Pioneer has great gear.
    B&W CM9Classé Sigma
  • dirtydenim86
    anonymouse wrote: »
    I ended up upping my budget and going with the Onkyo 809 hopefully I won't regret it there were some good reviews and some with overheating issues hopefully I don't run into those.
    But my setup is going to be:
    RTI10's in the front
    RTi4's in the rear
    CSi5 Center Speaker
    PSW505 Sub 12"
    and the Onkyo 809 Receiver
    Onkyo TX-NR809
  • cfrizz
    Well done, you are well on your way to having one rocking system.
  • dirtydenim86
    cfrizz wrote: »
    Thanks!
    I am however a little worried about the layout of my basement for a home theater cave.
    I will post up some photos of my room in a bit to see what you guys think of my plan I initially wasn't going to go with tower speakers but the deal caught me off guard a bit lol
    Onkyo TX-NR809
  • michael1947
    michael1947 Posts: 775
    I just got an e-mail from ebay tonight about an Onkyo TXSR 870 that was posted for sale. I already have it's little brother, an 805, so I don't need it. It has a buy it now price of 375 and that would be money spent...and would take care of your set-up. best of luck
    Main Family Room: Sony 46 LCD, Sony Blue Ray, Sony DVD/VCR combo,Onkyo TXNR 708, Parasound 5250,
    Living Room: Belkin PF60, Parasound HCA2200, MIT ProlineEXP balanced IC's,Emotiva XDA-1 DAC/Pre,Emotiva ERC2 transport,MIT AVT2, Polk LSI 9's.
  • cowtrimmer
    cowtrimmer Posts: 201
    RTi4's in the rear
    CSi5 Center Speaker
    PSW505 Sub 12"
    My 809 runs cooler than my 609 did running the same speaker setup. Its a good middle of the road AVR and you should be happy with it for $500 +or- price tag.
  • xftman
    xftman Posts: 153
    edited January 2013
    MAIN:
    Front- LsiM 707 (MIT Terminator 2 Bi-Wire),
    Center- lsiM 706,
    Surrounds- lsi F/X,
    Power sub PSW1000,
    Receiver- Harman Kardon Avr 3700,
    Amp - Emo XPR-5.
    Secondary (2.1):
    LsiM 703,
    HK Avr 3700,
    Yaqin MS-30L,
    Polk DSW-PRO 400.
  • dirtydenim86
    edited January 2013
    xftman wrote: »
    Damn I actually ended up buying it and then it went on sale just yesterday for $30 less so I ended up getting it for $450 + tax.
    Man I feel alot better about jumping on that now.
    Onkyo TX-NR809
    EndersShadow Posts: 17,704
    edited January 2013
    xftman wrote: »
    Eh, you can still get refurbs at A4L of both it and the 709 for decent prices and those will stay the same..
