Good Quality 2 Channel Amp @ least 200WPC
tophatjohnny
Looking to hear my SDA 1B's sing a little more than the Onkyo TX SR805 allows, so here I go on a hunt. I am posting as someone here may have an answer. Thanks and Pm if you have something.
Post edited by tophatjohnny on
What if it is only 198 watts per channel?:cheesygrin:
I'd have to pass!!
Current (not watts) should be your main goal! A high currant 100 watt amp will outproform a 200 watt low cutrant amp!!!Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable -
soundfreak1 wrote: »Current (not watts) should be your main goal! A high currant 100 watt amp will outproform a 200 watt low cutrant amp!!!
Yes I am looking for a high current 200 watt (at least) amp! Thanks for pointing that out."if it's not fun, it's not worth it & remember folks, "It's All About The Music"!!
Tru dat! And a 100 wpc high current amp that is stable to 4 ohms would prob be putting out close to 200 wpc anyhoo. -
By changing the Onkyo to 4ohm setting the speakers are singing like birds right now. Feeling pretty dumb!!"if it's not fun, it's not worth it & remember folks, "It's All About The Music"!!
PM TNHNDYMAN as he may have something you can use. I know he had a couple Adcom's that would serve well for you.
soundfreak1 also had a 2-ch amp for sale I think too. PM him as well.
Hope you find something! -
Does it need to be WAF friendly or cosmeticaly correct? If not, I have a professional Crest 4000 with 800wpc at 2 ohms
Computer room Hegeman 1 SpeakersM&K VX-80 subKenwood DP-7010Cambridge Audio CXC Transport Rega DACPrimaLuna Prologue Four AmpAric Audio Tube PreampGarage Jennings Research SquareCustom tube preampCrown XLS-1000Denon DCD-1500II Modded MSB Link DAC -
I should have said, I want it looking good and more of an amp that is made for home stereos. Thanksstarkiller wrote: »Does it need to be WAF friendly or cosmeticaly correct? If not, I have a professional Crest 4000 with 800wpc at 2 ohms
You would be hard pressed to find a 200wpc that has low current.
Tophat, by changing the setting on the Onkyo from 8 to 4 all you have done is tell the receiver to limit what little bit of power the receiver was sending to the speakers in order not to burn up the receiver. Switch it back but watch the volume until you can get an amp.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
Tophat- I do have an Adcom 5400 for a buck a watt $200 if interested. PM and I'll be happy to discuss and sort out shipping details. Call it a Christmas special- 200 shipped total price.2-ch System: Parasound P/LD 2000 pre, Parasound HCA-1000 amp, Parasound T/DQ Tuner, Phase Technology PC-100 Tower speakers, Technics SL-1600 Turntable, Denon 2910 SACD/CD player, Peachtree DAC iT and X1asynchorus USB converter, HSU VTF-3 subwoofer.
Think I saw in another thread where Denron was going to demo a 555 for you. Might be more money, but if he is selling I'd rather have the 555 myself. Nothing wrong with the 5400 just not quite at the 555's level or reputation.2-ch System: Parasound P/LD 2000 pre, Parasound HCA-1000 amp, Parasound T/DQ Tuner, Phase Technology PC-100 Tower speakers, Technics SL-1600 Turntable, Denon 2910 SACD/CD player, Peachtree DAC iT and X1asynchorus USB converter, HSU VTF-3 subwoofer.
Why switch it back when the specs on the SDA 1B's show normal impedance 4ohms???"if it's not fun, it's not worth it & remember folks, "It's All About The Music"!!
The receiver to limit what little bit of power the receiver was sending to the speakers in order not to burn up the receiver. It's not about what the specs on the SDA's say, they will handle anything you throw at them. It's about what the receiver CANNOT handle without risk of burning itself. up! When you put the switch on 4, it is simply throttling the power back it sends to the SDA's even more.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
"...The receiver to limit what little bit of power the receiver was sending to the speakers" in order not to burn up the receiver. It's not about what the specs on the SDA's say, they will handle anything you throw at them. It's about what the receiver CANNOT handle without risk of burning itself. up! When you put the switch on 4, it is simply throttling the power back it sends to the SDA's even more.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
High current is what drives Polks, so look for any amp that doubles it's power from 8ohms to 4ohms as a general rule. Will the Onkyo be used as the preamp?
PM sent. -
I ran a 5400 with my SDA 2A's and it did a fine job, had to put a jumper on the black terminals as it wasn't common ground. I didn't notice a earth shattering difference when I bought a 555, just more volume at a lower setting. $200 shipped on that 5400 would have those SDA sounding good.
What a great price! -
Thanks to all that chimed in and offered help. I am buying the Parasound 1200 from forum member jmwest1970 and we talked a little but ago. he sounds like a great guy and one I am comfortable doing business with. Looking forward to hearing the Parasound make my SDA 1B's really sing! Yahoo!!!!:cool:"if it's not fun, it's not worth it & remember folks, "It's All About The Music"!!
You are going to be truly impressed with that amp! I will never sell mine. It is a killer with polks! Makes them jump up and dance. LOL.Main Rig:
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
soundfreak1 wrote: »You are going to be truly impressed with that amp! I will never sell mine. It is a killer with polks! Makes them jump up and dance. LOL.
Thanks and I am excited about it. Now I am deciding what cables to get to hook it up to the Onk!"if it's not fun, it's not worth it & remember folks, "It's All About The Music"!!
Congrats tophat, I'm sure it will be a very nice piece of gear that will light those polks up!2-ch System: Parasound P/LD 2000 pre, Parasound HCA-1000 amp, Parasound T/DQ Tuner, Phase Technology PC-100 Tower speakers, Technics SL-1600 Turntable, Denon 2910 SACD/CD player, Peachtree DAC iT and X1asynchorus USB converter, HSU VTF-3 subwoofer.
What pre? The parasound just loves tubes!!!Main Rig:
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
Hope it loves the Onkyo TX SR 805 too???"if it's not fun, it's not worth it & remember folks, "It's All About The Music"!!
Good for you Johnny I was on the fence and really was thinking hard and figured that if it was still around after the holidays, it would be a great addition to match up with a pair of 2Bs then add my Adcom to drive a pair of CRS+s you beat me to it and I think you are going to be happy. I should sleep well tonight and keep looking for another Adcom as I really like mine. I bet you are going to enjoy that 1200 congrats.Home Theater
Thank you very much. Talk about the fence.....I was thinking a new (old school) receiver, and then just read all the comments the members were making to me, and read up a little o the Parasound 1200, crossed my fingers that it was still available, and lucky I was. The seller is so cool, and knows his stuff too! I can't wait to hear the difference it makes to my speakers. Again, thanks and hope you get the amp you want too!"if it's not fun, it's not worth it & remember folks, "It's All About The Music"!!
Congratulations Johnny,I think your gonna love it.
Dan -
Congrats!
Oldfatdogs wrote: »Congratulations Johnny,I think your gonna love it.
Danastar13656 wrote: »Congrats!Congrats!
Thanks you all cool cats!! Love this Polk sickness!!"if it's not fun, it's not worth it & remember folks, "It's All About The Music"!!
