why do some amps make thump when pwr up
leftwinger57
I ask this because thankfully my Adcom has no such problem but I do remember that a few expensive brand amps did.
Now mind you this was back in the 70's so I really do not know if it still holds true. One friend had the industrial
looking Mcintosh 2100 to power his bass guitar rig ala Jerry Garcia.He always told me before powering on the amp
make sure the volume pods were at low or off or a pop would occur and could blow his Gauss and JBLs. An other
friend had a Mac 2105 w/ a c-28 pre w/ ESS Heil AMT 1s and I was told the same thing.Is this an inherent thing w/
Macs or one of those amplifier anomalys that you just have to deal with?
My Adcom 5400 thumps to.
Lots of Carvers do this. My M1.0t does and so do many Carvers and other amps."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963)
EndersShadow wrote: »Lots of Carvers do this. My M1.0t does and so do many Carvers and other amps.
Yup. My TFM-42 did this when I owned one. -
The Carver "TFM" series amplifiers had a delayed turn-on, never heard a power supply pop from them. Yes they may have had a turn-on noise when the relay pulled-in but not a pop.
It's caused by an inrush of current as the power supply filter caps charge; as already stated. There are very few modern amps that do this as most have soft-start circuits (inrush current limiting to slowly charge the caps) and thump protection to slowing drain the caps when the amp is turned off. This is a circuit that can be added to most older amps, but more the most part it is harmless.
My TFM-45 thumped every time on shutdown since the day I got it, but did not on start up. Then recently, it started thumping a lot louder, and sometimes would squeal a bit on start up. I got afraid I'd damage my speakers, and took it out of service. It needs to be gone through and "refreshed".Sunfire Theater Grand IV
SRS 2.1TL
SDA 2BTL's
CSiA6
FXiA4
FXiA6
SDA 2A's
Monitor 10A's
http://www.douglasconnection.com -
some highend companies believe this protection circuitry degrades the sound of the amp( the less the better).Amplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156 -
That thump just indicates that the amp is gettin' ready to whup a$$ and take names ! :cheesygrin:
Some high-end companies believe (or at least write about) all sorts of strange nonsense!
But a soft-start circuit is a lot trickier to design than it would first appear.
