265-RT: What is the Recommended minimum net volume of the enclosure ?
landjoin
how about 255c-RT?625-RT?:question:
thanks.
thanks.
Hi landjoin,
Welcome to Polk's forum. Are you wanting to build an enclosure for them or are thinking about the volume of air behind the wall?
Regards, Ken -
Kenneth Swauger wrote: »Hi landjoin,
Regards, Ken
hi kenneth,
i'm thinking about the volume of air behind the wall,because my home wall is brick-concrete wall. i want to know how much volume of a hole i will dig? -
2012-12-21,the end of the world?:cheesygrin:
Hi,
Sorry I missed your reply. The 625-RT has a mounting depth of 3.5" and the 255C-RT has a mounting depth of 3 7/8", according to the specifications Polk has on the web site. Are you thinking you would need to remove some of the brick/concrete to install the speakers?
Regards, Ken -
Kenneth Swauger wrote: »Hi,
Regards, Ken
yes, I am ready to remove some of the brick/concrete.
I almost despair. Thanks,ken.
Merry Christmas! -
Wow I could ask the same question except with reference to the 625RT. Mine are in an exterior wall and I was worried about temperature and dirt getting at the driver so I built an enclosure of 1" pink styrofoam insulation. Perhaps I should be concerned about the volume. Should I drill a hole in the bottom piece to let air escape? I use them as presence speakers.AVR: Integra DTR-50.4
TV: LG 50PS70
DVD/CD/BR: OPPO BDP 93
MAINS: Polk RTiA7
CENTER: Polk CSiA6
Heights: Polk VS 625RT (in wall)
SURROUNDS: Polk TC60i (in ceiling)
REARS: Polk R1
SUB: Polk PSW 125 -
Hi,ken
I still did not get a reply.
help me,please.
I bought your product has for four months. I still can not use it now.
I just want a specific data. -
Hello,
Polk recommends 1.0 to 1.2 cubic feet sealed enclosure behind the speakers.
Regards, Ken
