Is my Polk Monitor 10A tweeter a Denmark Peerless.? It is # 75142478
pglbook
pglbook Posts: 2,267
edited December 2012 in Speakers
I need to replace a Peerless tweeter from one of my Polk Monitor 10A speakers and I need to find out if it is a Peerless tweeter made in Denmark or if it is a Peerless made in the USA (there were 2 versions).
I unscrewed the tweeter and pulled it out of the cabinet and on the back of the tweeter is the follwing # 75142478.
I read somewhere that the Peerless tweeters made in Denmark were # 75441880 but, while my tweeter begins with 75, the other numbers do not match. (I also read the the USA-made Peerless were # 55141081).
I have located a replacement pair near me which are Peerless tweeters made in Denmark and I want to make sure that the tweeters in my Monitor 10A are also ones made in Denmark so I know that the repalcement tweeter will be the same. I plan on replacing just the one bad tweeter as the tweeter in the other receiver is fine.
Thank you.
  • gdb
    gdb Posts: 6,012
    Hint: buy all you can find/afford,both types.:smile:
  • soundfreak1
    soundfreak1 Posts: 3,414
    Dont recomment replacing one only! Tough to have a good matc. Should be replaced in pairs. Imho
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
  • pglbook
    Thanks for your reply. I was wondering it it would be better to change both (in terms of compatibility) rather than to just change the one tweeter. It seems like I'll be changing both. Now I have to find someone to help me do this as I have no electronics experience, am mechanically-challenged, and have no idea how to solder. Unfortunately, the tweeter wires on the Monitor 10As are soldered on and not the clip on type.
  • pglbook
    I found out that the tweeter is one of the "made in Denmark" Peerless tweeters. Thanks.
