Turntable Question
laotzu61
i have a kenwood kd-2000 table. when an lp is finished playing, there is a "hum" or "feedback" thru the tonearm and other parts of the table. ( i don't know any other way to explain this) is it possible this is happening because i do not have the table grounding wire connected to anything? thanks.
"The symbol is not the reality"
Post edited by laotzu61 on
Could be, I take it you dont have a ground plug on your reciever to connect it to?"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
there is a gound connection on the amp, (have amp, preamp, cd player, table) but because of the "logistics" of my set-up, the ground wire from the table is not long enough to reach the amp. thanks."The symbol is not the reality"
What cartridge are you using?2 ChannelTurntable - VPI Classic 2/Ortofon 2M BlueAmplification - Rogue Audio Cronus Magnum II, Parks Audio Budgie PhonoSpeakers - GoldenEar Triton 17.2 Home TheaterDenon AVR-X3300W; Rotel RMB-1066; Klipsch RP-280F's, Klipsch RP-450C, Polk FXi3's, Polk RC60i; Dual SVS PB 2000's; BenQ HT2050; Elite Screens 120"Man CaveTurntable - Pro-Ject 2.9 Wood/Grado GoldAmplification - Dared SL2000a, McCormack DNA 0.5 DeluxeCD: Cambridge AudioSpeakers - Wharfedale Linton 85th Anniversary; LSiM 703; SDA 2A
Ok...I know some Grado carts don't like some tables and will hum or buzz at the end of the lp.
Is there any way you can move your table just to test it with the ground wire connected?2 ChannelTurntable - VPI Classic 2/Ortofon 2M BlueAmplification - Rogue Audio Cronus Magnum II, Parks Audio Budgie PhonoSpeakers - GoldenEar Triton 17.2 Home TheaterDenon AVR-X3300W; Rotel RMB-1066; Klipsch RP-280F's, Klipsch RP-450C, Polk FXi3's, Polk RC60i; Dual SVS PB 2000's; BenQ HT2050; Elite Screens 120"Man CaveTurntable - Pro-Ject 2.9 Wood/Grado GoldAmplification - Dared SL2000a, McCormack DNA 0.5 DeluxeCD: Cambridge AudioSpeakers - Wharfedale Linton 85th Anniversary; LSiM 703; SDA 2A -
Just extend the wire. Never hurts to try.If you can't hear a difference, don't waste your money. -
it would be very difficult due to the way it's set up, which i can't change. would it be possible somehow toadd some sort of extension to the spade connection from the table?"The symbol is not the reality" -
Extend the ground useing whatever wire you have handy to ground it. Wrap spade to wire with electric tape if thats all ya have. No ground is the problem.
thankyou. i will try that later today and get back to you guys. and thanks to all of you. :cheesygrin:"The symbol is not the reality" -
Let us know if that does not work (unlikely). -
You can extend the ground wire by soldering another to it. Even "I" can do that, and that's not saying much! lol There is a "reason" those TTs have that Ground wire on them. I never heard of anyone NOT using it!
Good luck!
finally got 'er done!! yee hah! made all the difference in the world. put on "sade--promise" lp just now, and no feedback. boy is this sweet! my audio cabinet is a 7' high 3 1/2' wide 26" deep solid cherry wood, beautiful piece of furniture, that is challenging to say the least when i need to re-wire or change anything; but well worth any problems i encounter when i'm done manipulating, bending, cussing, etc. thanks for all the help, guys. i appreciate it."The symbol is not the reality"
How abouts some pics of this cool piece of furniture and your gear
.... "....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
Tip: A simple clothespin makes a fine spring clamp that could serve to hold a wire & a spade connector together long enough for testing purposes.
Add a ground,if that doesn't help try reversing polarity on AC at outlet! You really ought to hook up that ground though!
EndersShadow wrote: »How abouts some pics of this cool piece of furniture and your gear
if someone will please let me know how to upload pics, i will tonight. thanks."The symbol is not the reality"
