Turntable Question
laotzu61
laotzu61 Posts: 327
edited December 2012 in Electronics
i have a kenwood kd-2000 table. when an lp is finished playing, there is a "hum" or "feedback" thru the tonearm and other parts of the table. ( i don't know any other way to explain this) is it possible this is happening because i do not have the table grounding wire connected to anything? thanks.
"The symbol is not the reality"
Post edited by laotzu61 on
    EndersShadow Posts: 17,749
    laotzu61 wrote: »
    Could be, I take it you dont have a ground plug on your reciever to connect it to?
  • laotzu61
    laotzu61 Posts: 327
    there is a gound connection on the amp, (have amp, preamp, cd player, table) but because of the "logistics" of my set-up, the ground wire from the table is not long enough to reach the amp. thanks.
  • hochpt21
    hochpt21 Posts: 5,423
    What cartridge are you using?
  • laotzu61
    laotzu61 Posts: 327
    audio technica #at-105/stylus #207-d7.
  • hochpt21
    Ok...I know some Grado carts don't like some tables and will hum or buzz at the end of the lp.
    Is there any way you can move your table just to test it with the ground wire connected?
  • decal
    decal Posts: 3,205
    hochpt21 wrote: »
    Just extend the wire. Never hurts to try.
  • laotzu61
    laotzu61 Posts: 327
    hochpt21 wrote: »
    it would be very difficult due to the way it's set up, which i can't change. would it be possible somehow toadd some sort of extension to the spade connection from the table?
  • chumlie
    chumlie Posts: 8,658
    Extend the ground useing whatever wire you have handy to ground it. Wrap spade to wire with electric tape if thats all ya have. No ground is the problem.
  • laotzu61
    laotzu61 Posts: 327
    chumlie wrote: »
    thankyou. i will try that later today and get back to you guys. and thanks to all of you. :cheesygrin:
  • ErasmusBDragon
    ErasmusBDragon Posts: 113
    laotzu61 wrote: »
    Let us know if that does not work (unlikely).
    You can extend the ground wire by soldering another to it. Even "I" can do that, and that's not saying much! lol There is a "reason" those TTs have that Ground wire on them. I never heard of anyone NOT using it!
    Good luck!
    cnh
  • laotzu61
    laotzu61 Posts: 327
    finally got 'er done!! yee hah! made all the difference in the world. put on "sade--promise" lp just now, and no feedback. boy is this sweet! my audio cabinet is a 7' high 3 1/2' wide 26" deep solid cherry wood, beautiful piece of furniture, that is challenging to say the least when i need to re-wire or change anything; but well worth any problems i encounter when i'm done manipulating, bending, cussing, etc. thanks for all the help, guys. i appreciate it.
    How abouts some pics of this cool piece of furniture and your gear :smile:....
  • gdb
    gdb Posts: 6,012
    Tip: A simple clothespin makes a fine spring clamp that could serve to hold a wire & a spade connector together long enough for testing purposes. :wink:
  • Msabot1
    Msabot1 Posts: 2,098
    Add a ground,if that doesn't help try reversing polarity on AC at outlet! You really ought to hook up that ground though!
  • laotzu61
    laotzu61 Posts: 327
    if someone will please let me know how to upload pics, i will tonight. thanks.
