minor problem w/ receiver
leftwinger57
leftwinger57 Posts: 2,917
edited December 2012 in Electronics
I got a little Kenwood vr-615 the other day from Good Will for $15.Now this is just being used for a minor system
in my bdrm.Even though originally it was a cheapo HTIB deal I am just using it for 2 channel radio.The problem is when I plug in my headphones they work but the main speakers do not cut off which is a feature I would want and I am
used to.Now that the unit was so cheap and all other features work I was just wondering if this a used item defect
or part and parcel w/ this unit.
  • decal
    decal Posts: 3,205
    Some units do not disconnect main speakers when headphones are plugged in, that's all.
  • Irrenhaus
    Irrenhaus Posts: 1,105
    Does the receiver have an on/off button for the speakers..
    HTAVR-Pioneer SC99XPA-DR3 Differential Reference AmpPolk R-700Rear- RT150Side- RT150Center-CSi5Sub-Rythmik audio F25Player- Panasonic DP-UB9000Projector- Optoma CinemaX P2Screen- Silver Ticket Products STR Series 6 120"Audio Room 2ch rig.Cary AE-3, Onkyo M-504, Marantz SA8005, Azur 851NWharfedale - Linton, SVS SB12-NSDMinis Forum PC (streamer) and Panamax MX5105Headphone rig;Schiit JOTUNHEIM and different headphones.Samsung 42" flat screen TV.
    Good point. If there are A/B speaker buttons on the front you probably have to disengage the speakers when you use the HPs. I have a few year old Yamaha integrated that "requires" this (not that old at all). I just push the A button so that it is in the off position when I use the HPs. I know that's less convenient than my Onkyo where the HP automatically deactivates the speakers. But hey, what can you do?
    cnh
  • leftwinger57
    Yeah ,Thanks I found the switch.It is a speaker cut /off switch right under the power button ,turn it off it enables the h/phs.
