minor problem w/ receiver
leftwinger57
I got a little Kenwood vr-615 the other day from Good Will for $15.Now this is just being used for a minor system
in my bdrm.Even though originally it was a cheapo HTIB deal I am just using it for 2 channel radio.The problem is when I plug in my headphones they work but the main speakers do not cut off which is a feature I would want and I am
used to.Now that the unit was so cheap and all other features work I was just wondering if this a used item defect
or part and parcel w/ this unit.
Some units do not disconnect main speakers when headphones are plugged in, that's all.If you can't hear a difference, don't waste your money.
leftwinger57 wrote: »I got a little Kenwood vr-615 the other day from Good Will for $15.Now this is just being used for a minor system
Does the receiver have an on/off button for the speakers..HTAVR-Pioneer SC99XPA-DR3 Differential Reference AmpPolk R-700Rear- RT150Side- RT150Center-CSi5Sub-Rythmik audio F25Player- Panasonic DP-UB9000Projector- Optoma CinemaX P2Screen- Silver Ticket Products STR Series 6 120"Audio Room 2ch rig.Cary AE-3, Onkyo M-504, Marantz SA8005, Azur 851NWharfedale - Linton, SVS SB12-NSDMinis Forum PC (streamer) and Panamax MX5105Headphone rig;Schiit JOTUNHEIM and different headphones.Samsung 42" flat screen TV. -
Good point. If there are A/B speaker buttons on the front you probably have to disengage the speakers when you use the HPs. I have a few year old Yamaha integrated that "requires" this (not that old at all). I just push the A button so that it is in the off position when I use the HPs. I know that's less convenient than my Onkyo where the HP automatically deactivates the speakers. But hey, what can you do?
Yeah ,Thanks I found the switch.It is a speaker cut /off switch right under the power button ,turn it off it enables the h/phs.2chl- Adcom GFA- 555-Onkyo P-3150v pre/amp- JVC-QL-A200 tt- Denon 1940 ci cdp- Adcom GFS-6 -Modded '87 SDA 2Bs - Dynamat Ext.- BH-5- X-Overs VR-3, RDO-194 tweeters, Larry's Rings, Speakon/Neutrik I/C- Cherry stain tops Advent Maestros,Ohm model E
