New Emotiva XPR-2... 2 channel, 600 watts into 8 ohms, 1000 watts into 4 ohms
24
  • audio_alan
    audio_alan Posts: 770
    edited December 2012
    Besides the perceived problem with a 20 amp circuit (which won't be a problem for me, since I'll have 3 or 4 of them in my basement when I'm done building it)...
    Has anyone heard this Emotiva amp yet?
    Has anyone seen an unbiased review of it?
    Yes, I know there are a lot of haters out there (many who have never even owned or heard an Emo amp), but is there no chance that this company could actually create a product that would be worthy of talking about? Or are most people already convinced that they'll always be a crap company with products that are pure junk or "entry level"? :rolleyes:
    pitdogg2 Posts: 24,477
    For most a dedicated 20amp line is as easy as take out the 15amp breaker and drop in a 20 amp. As long as you have 12ga romax a breaker and a outlet is just that easy....
  • BlueFox
    BlueFox Posts: 15,251
    audio_alan wrote: »
    I don't know about the haters part. That sounds like a term used by those trying to stir the pot.
    Anyway, while looking through the Emo catalog, it occurred to me that Emo only has one line of gear. Other companies have various lines at different price points that allow the customer to select what level of quality and fidelity they want, and can afford. For example, I want a new AVR pre/pro, and NAD has a $3k and a $5k model to choose from. Emo only has a UMC-200 at $599. Why not another higher quality offering?
    Is the Emo business model aimed at the gullible who think a HT pre/pro maxs out at $599?
  • audio_alan
    Good thought, but I'd bet most builders would only wire houses with the minimum guage wire necessary for the installed breakers... meaning most 15 amp circuits are probably only wired with 14 awg. It would be worth a peek behind an outlet to see if you're lucky though...
    audio_alan wrote: »
    in my area most codes call for 12ga on outlets and 14ga min. on lighting when i rewired my house i used all 12ga. for me it just made sense.
  • audio_alan
    In that case, pitdogg2, you'd be all set. That might solve naturallight's problem of not having a 20 amp circuit, so he can try the amp. :lol:
    BlueFox - Regarding stirring the pot, no more so than when someone makes a comment like "Emotiva is to high performance stereo amplification as a Yugo is to a Ferrari 599." Just sayin'...
  • naturallight
    naturallight Posts: 689
    Well..it is a nice thought. BUT your dealing with builders. They cut costs at every corner they can, and go with min code.
    So your chances of having 12 ga. Romex behind your 15 amp outlet is probably nil.
    Plus the fact these outlets are all daisy chained together.
    SO..if you had the 12 ga...you would have to trace back all the outlets on the circuit. Then never use them again.
    Then were do you plug in the rest of your equipment? You would have to find an outlet NOT on that circuit..which would probably put you in another room, so you would have to run a heavy duty extension cable from that other outlet.
    Just NOT a good idea all the way around.
    I have no issue with it....if you want to try the amp..be my guest. I have no intention of buying an Emo amp..ever...LOL
  • BlueFox
    audio_alan wrote: »
    Perhaps, but at least in my mind calling people "haters" is a bit more provocative than simply stating an opinion via a car analogy. At least the car analogy has a basis in fact. Maybe instead of Yugo a Miata would have been more accurate.
  • teekay0007
    teekay0007 Posts: 2,289
    BlueFox wrote: »
    Anyway, while looking through the Emo catalog, it occurred to me that Emo only has one line of gear. Other companies have various lines at different price points that allow the customer to select what level of quality and fidelity they want, and can afford. For example, I want a new AVR pre/pro, and NAD has a $3k and a $5k model to choose from. Emo only has a UMC-200 at $599. Why not another higher quality offering?Is the Emo business model aimed at the gullible who think a HT pre/pro maxs out at $599?
    It appears to have occurred to you wrong - Emo has a new Pre/Pro coming out at $1500, the XMC-1 7.2 channel.
  • Jhayman
    Jhayman Posts: 1,548
    BlueFox wrote: »
    Nope only aimed at people who that snake oil costs a lot of money and if you spend a small fortune on your Mark Lev, or Krell and Bryston then you are going to defend that purchase tooth and nail..
    When as Emoitva has only one store and is a company owned by an audiophile who know the value of a good product.
    Having it Internet based cuts the costs exponentially and Dan knows this, the owner.
    Why do people bash it, have they actually heard Emo gear?
    If you have never heard Emo before and are basing your thoughts on the cost factor then Sir, you don't know what you're talking about..
    Do you really think an Amp made by anyone should cost the same as a brand new car or even a good used car, I mean come on it can't , it just can't..
    Unless they are over charging by thousands and thousands of $
    Emo has it right great product for a great price that's it..
    And no I'm not biased to Emo I have friends that have spent double even triple than me and have Bryston and Krell amps powering their systems and I did a lot of research before buying my Emo amp and my friends can't believe the sound and quality and mostly the price I paid..
  • BlueFox
    teekay0007 wrote: »
    Well. It doesn't exist yet. Vapor ware does not really count. Of course, if they do come out with higher-end gear then that implies the current line is entry level gear. Which is what some have been saying all along, and others fall all over themselves saying that it is high-end reference gear.
  • Jhayman
    BlueFox wrote: »
    Exactly if one consider Emoitva in that category then the same people Must consider Polk Audio in the same analogy..lol
    The Yugo and Ferrari analogy..
  • falconcry72
    falconcry72 Posts: 3,580
    I'd like to hear it just to know. My main problem is that I buy 99% of my gear used, and 1500 bucks can buy A LOT of amp on the used market..
  • teekay0007
    BlueFox wrote: »
    Don't sweat it, BlueFox, most of us here know that Emo gear doesn't cost enough to sound good to you! :rolleyes:
    Oooh, scratch that, I should have said, 'a lot of us...', 'cuz I shouldn't speak for those that I'm not sure of their opinion.
  • Jhayman
    BlueFox wrote: »
    What makes an amp entry level or high end gear?
    Is it price?
    Because all the reviews I have read about Emotiva Amps compared to other more expensive amps, 99% of the difference is just that the price..
    Here's a better analogy Emo is the Corvette and Mark Levison is the BMW
    What's the difference the corvette will kill the BMW in 0-60 and quarter mile, skid pad..
    The BMW is just that a status Symbol and that's it..
    Jhayman wrote: »
    Is it price?
    get a clue!!
    Jhayman wrote: »
    There's far more to it than price yes i have heard Emotive amps and I have heard others Ayre,Krell,Bryston,Rotel and many many more. For lack of a better term they(Emo) fit a price point and please stop telling us they sound as good as the brands you and I have listed. They don't and won't be in the same bracket. cost or not.
  • Jhayman
    get a clue!!
    I have many clues and they all lead to the same conclusion people are very gullible and way over pay for things that should not cost a lot..
    A Good salesman will sell you anything for any price including snake oil and make you believe it..
  • pearsall001
    pearsall001 Posts: 4,981
    I missed all that information in the "Audiophlie Handbook," maybe it's in the preface section? I'll have to go back & check. Thanks for making us all aware of this important fact though.
  • falconcry72
    Jhayman wrote: »
    Just out of curiosity, what models of amplifiers have you personally A/B'd against Emo amps? It sounds to me that you are as guilty of drinking the EMO snake oil as any "gullible high-end buyer" is of drinking his brand's snake-oil... that is, if said "gullible high-end buyer" also does not A/B different amps.
    I personally A/B equipment in my own rig all the time because I don't believe what ANYONE says about how gear sounds... not because I don't trust people, it's just that I know my ears like different things than other people's ears.
    I own an Emo XPA-5, and I am very happy with it for the price I paid for it; however, I have A/B'd it against other amps in my 2-channel system, and I have found other designs that blow it away.
    As I stated earlier, I'd be interested to listen to the new XPR-2, but based on my experience with the XPA-5, I'm not convinced that the increase in wattage will amount to a big enough increase in sound quality. Still interested to hear it, though.
    Come on Pearsall trust me I'm not knocking Emo mine was to the poster that came in today and is trying really hard to make ALL of us drink the Kool-aid...
    "Because all the reviews I have read about Emotiva Amps compared to other more expensive amps, 99% of the difference is just that the price.."
    ^^^ this was where my comment was based....
  • audio_alan
    In all fairness, can ANY of you say the new XPR-2 isn't as good as a Bryston, Krell, McIntosh, etc, without having put your ears on one? (I'm guessing most, if not all, of you haven't heard this particular model yet, including me.) Many manufactures make low, mid, and high end gear. Just because you heard what you consider to be a "low end" model in the past, doesn't mean this new model (and all models to come) will fit into that same category...
    Were all the brands you guys hold in such high esteem the best thing since sliced bread when they first came out, or did they evolve into the great brands that you know today? I'm guessing they all had lemons, including some models that were prone to early/frequent failures. Just something to think about.
  • teekay0007
    Uh-Oh! I didn't think I was supposed to drink the snake oil....It was my understanding that just a few drops in each ear was adequate. :lol:
  • Jhayman
    Falconcry72 the main reason I came to this forum is because I had heard that people hear like to bash Emotiva here and being here for a few hours it seems like they are right..so cruel..
    I have A/B directly but I did have a Rotel in my gear for a few months, it was my friends he blew his Preouts on his Pioneer SC-37 sent it in for repairs, so much for quality..
    I personally like the ound of my XPA-5 better..
    Then I go to my buds place he has a Bryston and Paradigm Studio 100's V5 and even he prefers my XPA-5 to his Bryston..
    I use PSB Image T6 line all round for my HT.
    I'm just sick of people thinking that its better because it cost more..
    I noticed you don't even have your XPA-5 listed in your sig, are you embarrassed.
    Yes there is a difference but it should not be just about $
    And don't get me started on interconnects that cost hundreds of $.
    I just laugh and no I don't recommend using the ones in the box but there is a called, I know I paid to much but they look awesome..
  • halo71
    halo71 Posts: 4,567
    Jhayman wrote: »
    So you admit to being a troll?:eek:
    --Gary--
  • Jhayman
    halo71 wrote: »
    Not at all but it seems people around here certainly like to brand new comers ASAP..
    I'm here to help others and contribute to others in need of advice..
    So with only a few posts under my belt you're being a bit harsh are you not..
  • halo71
    halo71 Posts: 4,567
    No not harsh at all. It just perplexes me why someone would deliberately sign up on a forum to defend an amplifiers pedigree. You are not the first so don't take offense. I would think people would have better things to do with their time though. If you like Emo, fine. If you don't like Emo, fine. I like Onkyo Integra amps, many here don't. And I don't really care. We all like what we like.
    --Gary--
  • headrott
    headrott Posts: 5,484
    Jhayman wrote: »
    I don't know that we all like to "bash" Emo gear. I just don't agree with people comparing Emo gear with higher quality gear such as Pass Labs, McIntosh, etc., etc., etc. The higher price of this higher quality gear is a direct result of superior design, superior parts used, and superior craftsmanship. Period. Inversely, the lower cost of Emo gear is due to lower quality parts, design , and craftsmanship. period. That is not bashing Emo gear, that is stating the obvious. This is apparent by how the respective gear sounds. By sounds, I mean: Tone, detail, sounstage, imaging, transparency, etc. etc. Better design, parts, and construction lead to better sound. Period. Simple, clear, and true.
  • teekay0007
    headrott wrote: »
    ....He said, prior to bashing the hell out of Emo gear!! :eek:
  • headrott
    teekay0007 wrote: »
    It appears that your interpretition of "bashing" and mine differ along with what is considered "high quality sound". That's fine.
