Audyssey users.............
Irrenhaus
Question
Can I set up two different group of speakers under Audyssey?
I a have 2 pairs of mains RTi12's for HT and some music and a pair of Linn Keilidh for plain stereo. I think I have seen that you can save different configs under the Audyssey setup, I will have to look more into it.
Cheers
Cheers
HTAVR-Pioneer SC99XPA-DR3 Differential Reference AmpPolk R-700Rear- RT150Side- RT150Center-CSi5Sub-Rythmik audio F25Player- Panasonic DP-UB9000Projector- Optoma CinemaX P2Screen- Silver Ticket Products STR Series 6 120"Audio Room 2ch rig.Cary AE-3, Onkyo M-504, Marantz SA8005, Azur 851NWharfedale - Linton, SVS SB12-NSDMinis Forum PC (streamer) and Panamax MX5105Headphone rig;Schiit JOTUNHEIM and different headphones.Samsung 42" flat screen TV.
Post edited by Irrenhaus on
Do you mean the Audyssey calibration from your Onkyo AVR or a separate calibration device? If it's the Onkyo then the answer is No.Gears shared to both living room & bedroom:
Integra DHC-80.3 / Oppo BDP-105 / DirecTV HR24 DVR /APC S15blk PC-UPS
Living room:
LSiM707's / LSiM706c / LSiM702 F/X's / dual JL Audio Fathom F113's / Parasound Halo A51 / Panasonic 65" TC-P65VT50
Bedroom:
Usher Dancer Mini 2 Diamond DMD's / Logitech SB Touch / W4S STP-SE / W4S DAC-2 / W4S ST-1000 / Samsung 52" LN52B750
Other rooms:
Audioengine AP4's / GLOW Audio Sub One / audio-gd NFB-3 DAC / Audioengine N22
audio-gd NFB-10.2 / Denon AH-D7000 -
Under normal Audyssey you can not save different configurations. IIRC under some Audyssey setups you can save one configuration to fall back on, but it usually requires the use of the "Audyssey Pro" installers kit.
What I do with my A7's is switch my Onkyo 808 to Direct mode for 2ch music. This bypasses Audyssey, and omits my subs from the system. Perhaps do something similar and use a good quality speaker selector switch for your mains. ?? -
I've never been a fan of Audyssey for 2 channel, as stated above, just shut it off for music."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
