New surrounds or new bookshelf speakers
Here's what I have or will have shortly. New Marantz 6007, 2 front RTi10's, CSi3 center, 2 RTi6's rear, and new HSU VTF-3MK4 sub. Have on order a Emotiva XPA 5 amp. I would like to go to a 7.1 set up and am looking for some opinions. I would like to go with wides but the wife has put her foot down and said no, where I have my set up the speaker would protude into the pathway into the kitchen on one end and the hall on the other, so I can somewhat agree with her. So plan b comes into play, I am looking at a front height set up. Now on to the questions, I am trying to decide between new rear speakers such as the FIxa4 or 6 or getting some new bookself speakers to use as the front height speakers. I hear the dipole set up is pretty awesome, does it make a difference that my back is against a wall, how would I place these speakers on a wall? Next option would be just leave the RTi6's in place and add some front height speakers something comparable to the RTi6's or maybe a step up to the LSi series. I appreciate any insight into either of these scenarios.
Thanks Ken
Thanks Ken
Panasonic 50"
Panasonic BPD 50
Marantz 6007
B&W CM9
B&W CM2BG
CM 1's
HSU 3MK4
XPA 5
Panasonic BPD 50
Marantz 6007
B&W CM9
B&W CM2BG
CM 1's
HSU 3MK4
XPA 5
How you liking that HSU sub?
Well I havn't set it up properly yet, just by sound so far, but it sounds really good! I'm waiting to get my amp before I use Audyessey again. So much better than my last sub, it just seems like it responds when it's supposed to instead of just booming all the time.Panasonic 50"
Panasonic BPD 50
Marantz 6007
B&W CM9
B&W CM2BG
CM 1's
HSU 3MK4
XPA 5
