DSW PRO 600 Burnt part
meanuc
meanuc Posts: 7
edited December 2012 in Troubleshooting
I have a burnt part labeled as C7 on a circuit board where the main power ties into the sub. I believe it is some sort of diode. Does anyone know what this is and where I can get one?
Post edited by meanuc on
    F1nut Posts: 51,945
    Give Polk a CALL on Monday. They won't sell you the part, but you can send it in to them for repair. Depending on what's what, they may even fix it under warranty.
    Oh yeah, C would indicate a cap.
  • ambiophonics
    ambiophonics Posts: 727
    I would contact polk or take it to a local service center. It's unlikely that the burned part was the only point of failure.
    2 Channel - Polk SDA-2BTL, Triad SA1, 1000VA Dreadnought, Ryff streaming via Control4 for Qobuz lossless audio
