kind of blue
sda2mike
does anybody know of a cd version that doesn't have HISS? it's the only miles in my collection that i can't stand on my main system...in the car, of course it's fine:)
thanks
mike
thanks
mike
Post edited by sda2mike on
even my lp has hiss to it its how it was mastered.
I'll take hiss over a filter any day.Good music, a good source, and good power can make SDA's sing. Tubes make them dance.
I don't recall hiss on the 20-bit remastered version I have on CD. Jimmy Cobb's ride cymbal has rivets, which make a sizzling sound, sort of a sustain. It could be partly that cymbal that's contributing to what sounds like hiss.
Just a thought."Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer -
drumminman wrote: »I don't recall hiss on the 20-bit remastered version I have on CD. Jimmy Cobb's ride cymbal has rivets, which make a sizzling sound, sort of a sustain. It could be partly that cymbal that's contributing to what sounds like hiss.
Just a thought.
no it's definately tape hiss..sda's are all over it, too..maybe the remaster you speak of, is worth a pull -
YMMV, but I've found this to be the best Kind of Blue on CD:
http://www.amazon.com/Kind-Legacy-Edition-Miles-Davis/dp/B001KL3GZO/ref=sr_1_2?ie=UTF8&qid=1355421046&sr=8-2&keywords=kind+of+blue+cd
The Sony Mastersound one is second best, the gold cd. But I like the Legacy version better.Good music, a good source, and good power can make SDA's sing. Tubes make them dance. -
Btw, you'll see some negative reviews of the Legacy version on Amazon, particularly because of the dual-disc format. I believe this was one of the titles that Sony pulled that little root-kit trick several years ago. I believe they pulled those back and they are no longer sold, after Sony took a beating for doing that. For example, there is feedback from 2005 complaining about the driver replacement nonsense that Sony did. But the release date in the link I gave you is from 2009. I beleive the version that is currently being sold is your basic "normal" cd.Good music, a good source, and good power can make SDA's sing. Tubes make them dance.
MFSL is soon to release a hybrid SACD version. I would expect great things. I just received the SACD of "In A Silent Way" yesterday. I will spin it tonight. I would expect great things from both.
"Have A Little Faith! And Everything You'll Face, Will Jump From Out Right On Into Place! Yeah! Take A Little Time! And Everything You'll Find, Will Move From Gloom Right On Into Shine!"- Arthur Lee -
Dependent on where you look, a Blu-spec CD and a K2HD CD version are also available. -
Hi!
Danny Tse
I am agree with your point of view and I also believe that with the passage of time a person could be got a lot of the knowledge about this.I think it could be very wonderful for the newly knowledge to hearing some great music.Abel444
