kind of blue
sda2mike
does anybody know of a cd version that doesn't have HISS? it's the only miles in my collection that i can't stand on my main system...in the car, of course it's fine:)
thanks
mike
thanks
mike
Post edited by sda2mike on
even my lp has hiss to it its how it was mastered.Klipsch The Nines, Audioquest Thunderbird Interconnect, Innuos Zen MK3 W4S recovery, Revolution Audio Labs USB & Ethernet, Border Patrol SE-I, Audioquest Niagara 5000 & Thunder, Cullen Crossover II PC's.
I'll take hiss over a filter any day.Good music, a good source, and good power can make SDA's sing. Tubes make them dance.
I don't recall hiss on the 20-bit remastered version I have on CD. Jimmy Cobb's ride cymbal has rivets, which make a sizzling sound, sort of a sustain. It could be partly that cymbal that's contributing to what sounds like hiss.
Just a thought."Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer -
drumminman wrote: »I don't recall hiss on the 20-bit remastered version I have on CD. Jimmy Cobb's ride cymbal has rivets, which make a sizzling sound, sort of a sustain. It could be partly that cymbal that's contributing to what sounds like hiss.
Just a thought.
no it's definately tape hiss..sda's are all over it, too..maybe the remaster you speak of, is worth a pull -
YMMV, but I've found this to be the best Kind of Blue on CD:
http://www.amazon.com/Kind-Legacy-Edition-Miles-Davis/dp/B001KL3GZO/ref=sr_1_2?ie=UTF8&qid=1355421046&sr=8-2&keywords=kind+of+blue+cd
The Sony Mastersound one is second best, the gold cd. But I like the Legacy version better.Good music, a good source, and good power can make SDA's sing. Tubes make them dance. -
Btw, you'll see some negative reviews of the Legacy version on Amazon, particularly because of the dual-disc format. I believe this was one of the titles that Sony pulled that little root-kit trick several years ago. I believe they pulled those back and they are no longer sold, after Sony took a beating for doing that. For example, there is feedback from 2005 complaining about the driver replacement nonsense that Sony did. But the release date in the link I gave you is from 2009. I beleive the version that is currently being sold is your basic "normal" cd.Good music, a good source, and good power can make SDA's sing. Tubes make them dance.
MFSL is soon to release a hybrid SACD version. I would expect great things. I just received the SACD of "In A Silent Way" yesterday. I will spin it tonight. I would expect great things from both.
"Have A Little Faith! And Everything You'll Face, Will Jump From Out Right On Into Place! Yeah! Take A Little Time! And Everything You'll Find, Will Move From Gloom Right On Into Shine!"- Arthur Lee -
Dependent on where you look, a Blu-spec CD and a K2HD CD version are also available. -
Hi!
Danny Tse
I am agree with your point of view and I also believe that with the passage of time a person could be got a lot of the knowledge about this.I think it could be very wonderful for the newly knowledge to hearing some great music.Abel444
