265-RT: What is the Recommended minimum net volume of the enclosure ?
landjoin
landjoin Posts: 5
how about 255c-RT?625-RT?:question:
thanks.
Post edited by landjoin on
  • [Deleted User]
    [Deleted User] Posts: 7,598
    edited December 2012
    Hi landjoin,
    Welcome to Polk's forum. Are you wanting to build an enclosure for them or are thinking about the volume of air behind the wall?
    Regards, Ken
  • landjoin
    landjoin Posts: 5
    Hi landjoin,
    Regards, Ken
    hi kenneth,
    i'm thinking about the volume of air behind the wall,because my home wall is brick-concrete wall. i want to know how much volume of a hole i will dig?
  • landjoin
    landjoin Posts: 5
    2012-12-21,the end of the world?:cheesygrin:
  • [Deleted User]
    Hi,
    Sorry I missed your reply. The 625-RT has a mounting depth of 3.5" and the 255C-RT has a mounting depth of 3 7/8", according to the specifications Polk has on the web site. Are you thinking you would need to remove some of the brick/concrete to install the speakers?
    Regards, Ken
  • landjoin
    landjoin Posts: 5
    Hi,
    Regards, Ken
    yes, I am ready to remove some of the brick/concrete.
    I almost despair. Thanks,ken.:lol:
    Merry Christmas!
  • Cuchulain
    Cuchulain Posts: 66
    edited January 2013
    Wow I could ask the same question except with reference to the 625RT. Mine are in an exterior wall and I was worried about temperature and dirt getting at the driver so I built an enclosure of 1" pink styrofoam insulation. Perhaps I should be concerned about the volume. Should I drill a hole in the bottom piece to let air escape? I use them as presence speakers.
    AVR: Integra DTR-50.4
    TV: LG 50PS70
    DVD/CD/BR: OPPO BDP 93
    MAINS: Polk RTiA7
    CENTER: Polk CSiA6
    Heights: Polk VS 625RT (in wall)
    SURROUNDS: Polk TC60i (in ceiling)
    REARS: Polk R1
    SUB: Polk PSW 125
  • landjoin
    landjoin Posts: 5
    edited April 2013
    Hi,ken
    I still did not get a reply.
    help me,please.
    I bought your product has for four months. I still can not use it now.
    I just want a specific data.
  • [Deleted User]
    edited April 2013
    Hello,
    Polk recommends 1.0 to 1.2 cubic feet sealed enclosure behind the speakers.
    Regards, Ken
