Goodwill finds.........
Irrenhaus
Irrenhaus Posts: 1,105
edited December 2012 in Speakers
Hello all:
I just pick up a pair of ADS L780/2 speakers at the local Goodwill store for $24.99 all drivers look intact and they need to be clean but not major scratches on the cabinets. I will have to wait till I get home tonight to fire them up. and see if they work.
There is a bit of rust around the woofer but no major things other that they are dusty. Any recommendations what to look before I get them connected to the amp.
cheers.
HTAVR-Pioneer SC99XPA-DR3 Differential Reference AmpPolk R-700Rear- RT150Side- RT150Center-CSi5Sub-Rythmik audio F25Player- Panasonic DP-UB9000Projector- Optoma CinemaX P2Screen- Silver Ticket Products STR Series 6 120"Audio Room 2ch rig.Cary AE-3, Onkyo M-504, Marantz SA8005, Azur 851NWharfedale - Linton, SVS SB12-NSDMinis Forum PC (streamer) and Panamax MX5105Headphone rig;Schiit JOTUNHEIM and different headphones.Samsung 42" flat screen TV.
    EndersShadow Posts: 17,753
    Connect a 9v battery to em and you can test if they work without any music. The 9v battery will make the woofers move so you can check for frozen magnets and whatnot without risk to your amp.
    http://www.soundspeakerrepair.com/speaker-parts-cp/Speaker-Testing-with-9-Battery/INST/Installation+Instructions/
    mhardy6647 Posts: 35,545
    I'd just go for it - but I keep a cache of "test equipment" around - For the record I worry far more about amplifiers damaging loudspeakers than the other way 'round.
    A fine deal - they are very good sounding loudspeakers.
    I've got a pair of their forebears - L-710 - playing even as I type this.
  • Irrenhaus
    Thanks for the tip.
  • soundfreak1
    soundfreak1 Posts: 3,414
    Talk about stepping in a bucket of @&#@ and comming out smelling like a rose. Nice deal.
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
  • PolkieMan
    PolkieMan Posts: 2,446
    1.5 volts is enough
  • goofyGAguy
    goofyGAguy Posts: 545
    Nice find. There's never anything at my local Goodwill except VCR's and 12" TV's.:neutral:
    My humble setup...
    ...is no more. :cry:
  • halo71
    halo71 Posts: 4,642
    ^ ditto
    --Gary--
  • Irrenhaus
    Well here is a quick update. Got home tested with a 1.5v batter and look good. But I am getting a reading of 4ohm at the terminals instead of 8ohm.
    With music one of the woofers sounds blown took a quick look inside and measured all drivers:
    woofer: 4ohm
    mid: 4ohm
    tweeter: 3.5ohm
    Next step for the weekend I will take a look at the crossovers and see if the caps are okay. Any tips.
    Cheers
  • cmy330go
    cmy330go Posts: 2,341
    What your meter is telling you is just DC resistance, and therefore won't match the impedance rating of the speaker. So don't let those values bother you. Impedance is a measurement of resistance to current in AC circuits that fluctuates with frequency. So the rating you see on speakers is really just an average over the typical operating range. Hence the reason you will see it occasionally listed as "nominal" impedance.
    HT
    Mits WD-65737, DirecTV, Oppo DV-970HD, XBOX ONE, Yamaha RX-A1030, Parasound Halo A23, Rotel RB-985, Music Hall MMF-7, Parasound PPH-100, LSi-15, LSi-C, LSi-FX, LSi-7, PSW-1000, Monster HTS2600
    2 CH
    Parasound Halo P3, Parasound Halo A21, Sutherland Ph.D, VPI Classic 3 w/ 3D arm & Soundsmith Aida Cartridge, Arcam CD72T, B&W 802 S3, Monster HTS2500,
  • 20hz
    20hz Posts: 636
    I never tried the 9v battery test on a built speaker I figured the xover would absorb the voltage before the drivers got anywhere but I will try it , still $25 if if any parts are good you came out ahead !
    ps: dont try a 9v on a tweeter :)
  • Tbone289
    Tbone289 Posts: 661
    20hz wrote: »
    It will with some designs.
    2.1: PC>Schiit Gungnir MB>Schiit Freya Noval>NAD C-270>Ascend Acoustics Sierra-1, HSU STF-2 5.1: HDMI Bitstream>Denon AVR-1910>polkaudio RTE55, CS350-LS, RT3, HSU STF-2, Visio M55-F0
  • Irrenhaus
    Well found this place online I think after lookig more in depth to the speakers over the weekend I will see if I get the drivers service. Only spent 25.00 on them so few more bucks is not a bad deal.
    http://www.adsspeakersservice.com/
    Cheers
  • DollarDave
    DollarDave Posts: 2,575
    Have you checked the fuses? I think those 780's have 2 per x-over.
  • Irrenhaus
    Hey
    @DaveMuell I check but I think the 780 had a fuse but the 780 v2 don?t.
    I spoke to the person in Arizona and he said he will recone all drivers and give me a good price plus a discount to do all. Even know the condition of the speakers I like how they sound at lower volumes and how they blend in.
    Now a pair of LINN Keilidh with the bases are available locally. It is about the same price of the rebuild. Damm what do I do, have plans to audition them tomorrow. They are in mint condition and I can always do the ADS later........
    I am just looking for a Merry Christmas to Me Present...........lol
  • Irrenhaus
    Irrenhaus wrote: »
    Hey
    Hey sorry for keep asking. But even know I am asking about non Polk speaker(I do love my 12's) it always help to get info on other brands that you the Polk comunity have try and have some insight on and is always welcome.......cheers
  • Irrenhaus
    How do I close a thread. I will move this one to the 2 channel side.
    Cheers
