Wire arrangement
acmf74
acmf74 Posts: 937
I have most of my gear on amp stands next to each other on the floor.
Should I keep my power cables away from my IC's?
Would wires close to each other introduce noise?
Thanks..
Post edited by acmf74 on
  • gp4jesus
    gp4jesus Posts: 2,019
    edited December 2012
    Yup. Otherwise cross them @ right angles.
    *all connected w/Premiere ICs
  • steveinaz
    steveinaz Posts: 19,545
    Get you some pull-ties and pull-tie stand-offs at the hardware. They work great for cable management. Also be careful of digital cables near analog IC's.
  • specd_out
    specd_out Posts: 505
    gp4jesus wrote: »
    Bingo. I used the velcro straps. this way you can reuse them
    Mine has never looked this bad. I have always bundled them. But this is all unwrapped showing what I had to work with
    This is all done
    Power wire run separately under the stand I/C and hdmi run together. Any overlap is at 90 degrees
    HT Rig Samsung 64F8500 |Pioneer Elite BDP-52FD|Pioneer Elite VSX-32| Two Carver TFM-15cb Bridged for mains|Polk Audio RTiA5 Cherry|Polk Audio CsiA6 Cherry|Polk Audio T-15 Heights|Polk Audio FXia6 Surround|DIY 8cuft Dayton Ultimax 15" powered with a Crown XLS1000
    2Channel Rig Polk Audio LSi9 Cherry| Carver C-1BillD Mod|Carver M1.0t MkII Opt2|Pro-ject RM 1.3|SpeedBox S|AQ King Cobras|AQ Rocket88|
    ISF Level 2 Certified Calibrator
