Wire arrangement
acmf74
I have most of my gear on amp stands next to each other on the floor.
Should I keep my power cables away from my IC's?
Would wires close to each other introduce noise?
Thanks..
Thanks..
Post edited by acmf74 on
Yup. Otherwise cross them @ right angles.Samsung 60" QN65Q7FAMFXZA QLED, Outlaw Audio 976 Pre/Pro, Samsung BDP, Amazon Firestick, Phillips CD Changer
*all connected w/Premiere ICs
4 dedicated 20A feeds; APC H15; 5 Furman Miniport 20s -
Get you some pull-ties and pull-tie stand-offs at the hardware. They work great for cable management. Also be careful of digital cables near analog IC's.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
Bingo. I used the velcro straps. this way you can reuse them
Mine has never looked this bad. I have always bundled them. But this is all unwrapped showing what I had to work with
This is all done
Power wire run separately under the stand I/C and hdmi run together. Any overlap is at 90 degreesHT Rig Samsung 64F8500 |Pioneer Elite BDP-52FD|Pioneer Elite VSX-32| Two Carver TFM-15cb Bridged for mains|Polk Audio RTiA5 Cherry|Polk Audio CsiA6 Cherry|Polk Audio T-15 Heights|Polk Audio FXia6 Surround|DIY 8cuft Dayton Ultimax 15" powered with a Crown XLS1000
2Channel Rig Polk Audio LSi9 Cherry| Carver C-1BillD Mod|Carver M1.0t MkII Opt2|Pro-ject RM 1.3|SpeedBox S|AQ King Cobras|AQ Rocket88|
ISF Level 2 Certified Calibrator
