Speakers RTi series vrs Monitor
Bogey
Bogey Posts: 5
edited December 2012 in Speakers
I am looking to purchase new speakers for my home theater. (5.1 older Kenwood receiver). I was wondering what the difference is between the two series. There is nowhere to demo the speakers so I have been reading reviews. Any help would be appreciated!
  • Bogey
    Bogey Posts: 5
    Also I am considering TSI 500
    F1nut Posts: 52,371
    The RTi A series are mo'better.
  • Bogey
    Bogey Posts: 5
    Thanks!
  • la9ers
    la9ers Posts: 117
    with the rti's you might need an amp to help power those speakers.... the monitors would be a better fit, they would work on almost any receiver.
  • lanchile
    lanchile Posts: 560
    RTi A series are very good speakers. I have the RTiA 1 (cherry) as main and they sound awesome!!!! just read reviews. They are small speakers, but they sound way way better than those big speakers. The highs are not ear's piercing, they are very clear!. The mid-range is very detailed and the bass is way deep for it size. Close your eyes and you will swear that you are listening to way bigger speakers. The best of all is, these speakers are not "fatiguing" so you can listen to them all day long. sound and build quality is top notch!!!
    Make it simple...Make it better!
  • Geoff4rfc
    Geoff4rfc Posts: 3,043
    Yes, way mo
  • gp4jesus
    gp4jesus Posts: 2,019
    Geoff4rfc wrote: »
    Yes, way mo
    "RTi A" series is the Advanced RTi series. Don't confuse 'em. Though they use the same tweeter & similar driver arays, "for best results," stay all "A" series. Do not mix 'n match 'em.
    BTW: how big is your room? In a small (14X12X8) room you could start w/RTi A3s for LR maybe w/either an SVS or HSU sub. Follow w/a CSi A4 for a CC. Later add pair of FXi A4s as side/surrounds.
    Bigger room? Bigger speakers! 'A5s or 'A7*/9*s for LRs & a sub; CSi A6, CC. Finish w/FXi A6s SS. Just some thoughts. Others will chime in agreement or w/better ideas.
    * depending upon receiver choice, "for best results," add 2/3 ch ex amp.
    Merry Christmas, Tony
    *all connected w/Premiere ICs
  • snake1
    snake1 Posts: 567
    RTi's are really good IMO! External amplification really makes them come alive especially down low but they can be driven decently with a good AVR until an amp can be purchased later.
    AVR - Onkyo NR809
    500gb HD for MP3 and FLAC files
    Amp - Parasound 2250 - FOR SALE BTW!! PM me if interested!
    Mains - Polk RTi12 towers
    Center - CSi5
    Surround - FXiA6's
    Sub - psw505
    Movies and games - PS3
    TV - Toshiba 52" HD
    Every vehicle has one good nuetral drop in it
  • seabeerob213
    seabeerob213 Posts: 1,843
    i have the RTI 4 which is the predecessor to the RTI-A 1, powered only with an AVR, and they sound amazing, they canbe picked up cheaper thanthe monitors if you shop around, fry's has the RTI 12 with a PSW 111 for 750 right now
    F1nut Posts: 52,371
    Who's got my decoder ring?
  • seabeerob213
    just found one in my box of cracker jack, you want it?
