RM95 (RM8) Speaker Stands
rm95
I recently got the RM95 setup (4 RM8's plus 1 RM8 Center). I am in search of speaker stands that are sturdy enough to hold these and will be compatible with the wall mount "L" brackets that came with the speakers. By compatible, I mean that most of these stands are designed for speakers with the threaded hole in the back, not the bottom so my plan is to use the L brackets with two screws (one to the stand, one to the speaker).
I am having a hard time finding a set. I know I can do trial and error but I'm trying to save some time, and if possible, having to fiddle with the stands to get them to fit.
Does anyone have a recommendation (links would be great too!)? I do know about Polk branded stands, but they are prohibitively expensive at this point.
Thanks!
Thanks!
Post edited by rm95 on
What did you do? I had the same thoughts about combining the fixed brackets with some articulated ones...
I'm having the exact same problem finding speaker stands that will work with my RM95's. I'm trying to make these work, but so far no dice.
Hello alex,
Welcome to Polk's forum. The Polk SA-3 speaker stand will fit your speakers.
Regards, Ken
