RM95 (RM8) Speaker Stands
rm95
rm95 Posts: 1
I recently got the RM95 setup (4 RM8's plus 1 RM8 Center). I am in search of speaker stands that are sturdy enough to hold these and will be compatible with the wall mount "L" brackets that came with the speakers. By compatible, I mean that most of these stands are designed for speakers with the threaded hole in the back, not the bottom so my plan is to use the L brackets with two screws (one to the stand, one to the speaker).
I am having a hard time finding a set. I know I can do trial and error but I'm trying to save some time, and if possible, having to fiddle with the stands to get them to fit.
Does anyone have a recommendation (links would be great too!)? I do know about Polk branded stands, but they are prohibitively expensive at this point.
Thanks!
