What used speakers for under $500 should I buy?
Looking for a set of speakers for my basement rig.
They will accompany
Yaqin MC-10L 50 watt integrated tube
Pioneer PL 550 turntable
Squeezebox
Small floorstanders or bookshelfs
Considering Klipsch Heresy etc.
I have had a lot of the "New England" sound which I do like. Currently running KLH 6's.
Looking for something different that will mate well w/ the aforementioned components.
Ideas???
They will accompany
Squeezebox
Ideas???
I got static in my head
around 500. Polk Lsi9s on Ebay is your best bet.
I have had the lsi7's in this system and they were bested by the klh 6's imo. So doubt I would try the lsi9s.I got static in my head
The reflected sound of everything -
you might be able to make a deal with this guy.
http://app.audiogon.com/listings/monitors-dynaudio-audience-42-rosewood-absolutely-mint-low-hours-2012-12-02-speakers-81303Amplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156 -
Dynaudios, always a safe choice and a good one, even if doro finds them boring and predictable (at least I think he does?).
I'd add, look at some vintage Tannoys if you're going to run tubes! They match up very nicely with tube amps. But certainly listen to everything mentioned and suggested so far and then listen to some "more"!
Happy hunting!
I think you'd be better served with spending that coin on a dac personally. The lsi's are a more revealing speaker than the KLH's and coupled with the SBT, and that noisy volume, could be what you were hearing.
How big is the room and how loud do you play it ? You may need a fairly efficient speaker if you like it loud in a big room.HT SYSTEM-
lsi 9's -
how much air do you have in your basement?
http://harrisburg.craigslist.org/ele/3367615572.html
and if that won't work you could try these....
http://harrisburg.craigslist.org/eld/3433438930.html
i have a pair of W-70s collecting dust in my garage i could let you try out
wayneYamaha RX-V2700, EMI 711As (front), RCA K-16 (rear), Magnavox Console (Center & TV Stand), Sony SMP-N200 media streamer, Dual 1249 TT =--- Sharp Aquas 60" LCD tellie -
Thanks lots of good answers.
The Dynaudios are definitely interesting but on the high end money wise.
Tannoys are definitely of interest. I dont see them come up much.
I have tried the LSI7 w/a few different systems and sources. They are definitely nice but they dont seem to do it for me.
The Maggies are too big. I would love to hear them.
The Wharfdales are the right price.
Wayne,
Where do you live? I am guessing Harrisburg area. I work in Hanover and am free during the day with notice. I would welcome the opportunity to check out the w-70's.
RickI got static in my head
also fyi- this is in a small room.I got static in my head
Rick,
I actually replaced my W-70s with a pair of MG-Is that i picked up off Baltimore Craigslist in June. I live on the Eastern Shore (Easton) and work in Annapolis.
So with a bit of preplanning we could get the W-70s to you.
WayneYamaha RX-V2700, EMI 711As (front), RCA K-16 (rear), Magnavox Console (Center & TV Stand), Sony SMP-N200 media streamer, Dual 1249 TT =--- Sharp Aquas 60" LCD tellie -
In the Klipsch line, instead of Heresy's, I would consider a pair of KG-4s for around $225 - $300. The tubes would fall in love.
Have you tried any A/D/S models? Maybe a pair of the later series L-710's, or L780's? For a little more bass, step into a pair of L-810's.
Heck, for $500 you can get into a pair of Vandersteen 2C's (my current running mates), but they may need a little more gas than the Yaquin. -
I would also look at horns with the tube amp. You might be able to find a pair of Fortes which are great; I prefer three-way Klipsch over two-way. Maybe a pair of Polk RTAs or KEF Q series?
polk rti 8's sound fantastic with the mc10. If you can swing $900 get some Martin logan source they are perfect or try some used maggies ?
Well it looks like I am going to try out Waynes Wharfedales. I also am talking to a guy about some DCM time window 1A's. Well see how these sound and then go from there. Fun!I got static in my head
I second Dave Muell's recommendation of the KG4s - I have a pair in my living room that I really like.
What are you doing with your KLH 6s?
I still have my pair (haven't done the tweeter replacement yet) and love them! HT System:
Marantz NR-1403
Front: Klipsch CF-4
Rear: Paradigm Atom V3
Center: Boston Acoustic VR12
Sub: Bowers & Wilkins ASW600
2Ch:
Restored Fisher 500C
Yamaha P-500 Turntable
Living Room:
Harman Kardon 3380
Restored Polk Monitor 7B
Bedroom:
Harman Kardon VR-3750
Cambridge Soundworks Ensemble
Polk PSW10
In and out of rotation:
KLH Model 6,
Polk LSI7
NAD 7100 -
Dave,
I have a pair of ads l420 that I like. I am definitely interested in chking out some klipsch kg4's. I emailed a cl listing for some kg4's w crites tweeters but got no response.
George,
I am keeping the klh 6's just wanna have a different sound for a bit. I want to rehab my 17s. Something is wrong with the highd is wrong w the 17I got static in my head
Good move with the 6s - I don't think I'll ever get rid of mine!
Rehabbing my 6s wasn't hard - as long as you have a version with the removable drivers - some 6s have glued-in speakers. I'm not sure if 17s are the same way. If they're screwed in the crossover is a cinch to upgrade with new caps. If you have any questions let me know - happy to help.
[this is all covered in another post somewhere else too...] In my experience that really opens up the high end. And when I replaced the caps I also found that one of the tweeters in one of the 6s was dead - from what I read online this can happen when a cap goes all-open and blows the tweeter. I found a replacement from a fellow Polkie but that tweeter has a buzz in it - I think that either it may also be failing or the voice coil may be rubbing. When I get around to my next big Parts express order Im going to try two of the phenolic tweeters on the site they advertise as replacements for vintage 2-ways. I'll let you know how it turns out.
Good luck!!!Dave,
George,
I am keeping the klh 6's just wanna have a different sound for a bit. I want to rehab my 17s. Something is wrong with the highd is wrong w the 17HT System:
Marantz NR-1403
Front: Klipsch CF-4
2Ch:
Living Room:
Harman Kardon 3380
Bedroom:
Polk PSW10
KLH Model 6,
Polk LSI7
NAD 7100 -
Well I had to pass on Waynes Wharfedale w70 due to room constraints. I did get a pair of KG4's w/Crites tweeters and I was surprised at how big they were. They barely fit! I was also surprised at how good the bass was. I was expecting shrill highs and little bass. However, they sound very nice. Looks like they may end up being keepers.
The Klipsch KG4's will be on basement duty along w/my KLH 6's. I will switch back and forth (i think) depending on mood and music. I havent a/b'd them yet but will do soon. I did a/b the Klipsch w/my SDA 1C's just for fun. SDA 1C's not going anywhere.I got static in my head
rromeo923, you could try Sony floorstanders. Or maybe Panasonic. Perhaps Bose is right up your alley?Do you hear that buzzing noise?
Monster Jam wrote: »rromeo923, you could try Sony floorstanders. Or maybe Panasonic. Perhaps Bose is right up your alley?
Because he likes the KG-4's you suggest a bunch of crap-**** speakers? Have you ever heard KG-4's with tubes?
BTW, not all Sony and Panasonic floorstanders are junk. You may even want to try a set of Sony M-5, 7, or 9's - they might make you question your investment in LSi's. -
All good. I can hear the deficiencies in the KG4's. They sound a little thin and can be a bit bright and shrill but they also got me up dancing. These are not bad speakers. The do some things very right. Got these for $225.
What do u suggest I listen to w/in my under $500 used parameters?I got static in my head
Upgrading the crossovers in Klipsch speakers with "warm" caps sounds great and adds a little more body to the sound; I've done it a few time with great success.
Well just figured out that these KG4's are the 4ohm model. Switched to the 4 ohm soeaker connection on my Yaqin. Fulller sound, better bass. Voila!I got static in my head
It keeps on getting better. It has been said that Horns love tubes. Well I swapped out some NOS Telefunken ECC88 that are by no means slouches for some Amperex Bugle Boys Nos 1959. Holy Moly! 3D midrange bliss!!
Love it!I got static in my head
Tubes and Klipsch. Yep. That works! And now you can roll till you "smile"!
Have fun!
