My receiver is not making any sound
EDUBAG
EDUBAG Posts: 403
edited December 2012 in Electronics
HEY GUYS,
for some unknown reason my receiver stop making any sound a couple of weeks ago. i turned off an back on and it was fine again, another day it stopped an i put it in direct mode and it sounded on again, however last friday it went mute, it does not even let sound go through to the tv via hdmi through. so i am guessing that it has something to do with the sound processor. but just in case do you guys know how to reset this kind of receiver? pio elite vsx23thx.
it is a very weird thing but it is happening and i cannot afford to change it right now.
i live in the dominican republic and it is not easy to fix electronics down here.
please advice with the reset option to see of that would help. thanks and best regards.
eduardo
HT:
POLK AUDIO RTI4 FRONTS
CSI3 CENTER
DEF TECH PROMONITOR800 SURROUNDS
PSW 125 SUB
PIONEER ELITE AVR23TXH AVR
APPLE TV 160GB
PANASONIC BLURAY PLAYER
50" PANASONIC PLASMA TCP50C2
2 CHANNEL:
KEF R300 THREE WAY BOOKSHELF GLOSS PIANO BLACK
ROTEL RC 990BX PRE
ROTEL RB 990BX AMP
OPPO DV980 (AS CD PLAYER)
PIONEER PL100 TURNTABLE WITH SHURE MX97E CART
MIT EXP2 SPEAKER CABLES
Post edited by EDUBAG on
  • EDUBAG
    EDUBAG Posts: 403
    more info just in case
    cablebox is connected to receiver via rca
    bluray via hdmi
    dvd via hdmi
    receiver to tv via hdmi
    it does not produce any sound at all no matter if i put it direct, or hdmi through.
    HT:
    CSI3 CENTER
    PSW 125 SUB
    APPLE TV 160GB
    2 CHANNEL:
    ROTEL RC 990BX PRE
    ROTEL RB 990BX AMP
  • skrol
    skrol Posts: 3,488
    Your receiver is likely going into protect mode. Make sure that you do not have any shorted speaker wires (ie at the speaker and receiver binding posts).
    It could be a shorted speaker. Try disconnecting all speakers and hooking up one known good speaker.
    Stan
    Main 2ch:
    HT:
    Other stuff:
    F1nut Posts: 52,301
    You could try unplugging it for an hour, but I doubt that will fix it. I suggest you contact Pioneer to see if they can be of help.
  • specd_out
    specd_out Posts: 504
    I also agree about it going in to protection. I would check all speaker wires. Disconnect them all visually inspect them. Then one speaker at a time check for sound.
    HT Rig Samsung 64F8500 |Pioneer Elite BDP-52FD|Pioneer Elite VSX-32| Two Carver TFM-15cb Bridged for mains|Polk Audio RTiA5 Cherry|Polk Audio CsiA6 Cherry|Polk Audio T-15 Heights|Polk Audio FXia6 Surround|DIY 8cuft Dayton Ultimax 15" powered with a Crown XLS1000
    2Channel Rig Polk Audio LSi9 Cherry| Carver C-1BillD Mod|Carver M1.0t MkII Opt2|Pro-ject RM 1.3|SpeedBox S|AQ King Cobras|AQ Rocket88|
    ISF Level 2 Certified Calibrator
  • EDUBAG
    EDUBAG Posts: 403
    But the video part is working fine. Wouldnt protect block the whole thing?
    HT:
    CSI3 CENTER
    PSW 125 SUB
    APPLE TV 160GB
    2 CHANNEL:
    ROTEL RC 990BX PRE
    ROTEL RB 990BX AMP
  • Drenis
    Drenis Posts: 2,871
    Try resetting the HDMI board. There is a process on how to do it somewhere. VR3 did this not too long ago, may ask him.
    Just a suggestion. Usually these are solid AVR's. I had a 23 myself.
